Old 01-18-2004, 03:11 PM   #1
ImprezaWRX02
Member#: 12500
Default CEL codes
Does anyone know wht would cause these CEL codes? I went to the suby dealer and they had no clue lol.
P0103 Mass air flow sensor circuit high input
P0546 Exhaust gas temperature sensor circult high input
P1312 Exhaust temperature sensor malfunction
I'm think the last 2 are from my catless downpipe?
ImprezaWRX02 is offline   Reply With Quote
Old 01-18-2004, 09:06 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Dealer had no clue?? Find another dealer and don't take your car back to that one.
The catless downpipe will give you a P0420 catalyst inefficiency code. If you don't have one now you will eventually when you do enough highway driving.
The 0103 indicates a MAF problem, it could be bad or just have a poor connection. Have you done any intake mods?
The 0546 and 1312 are from a problem with your EGT probe in the uppipe. Is your uppipe stock or catless, and is the probe still installed? If you have a stock uppipe and the probe is bad, replace it with a new one. If it's a catless pipe, you can remove the probe, plug the hole and put a 2.2K ohm resistor in the connector.
Old 01-20-2004, 12:42 PM   #3
ImprezaWRX02
Member#: 12500
thanks for the reply, yes i have a pde catless uppipe and an ame cold air
Old 01-20-2004, 09:49 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
sounds like something is unplugged.
Jay
STG2: Flashing CEL but no CEL code mvitic AccessPort 1 08-10-2006 09:43 PM
HELP: where can I borrow a CEL code reader or get the code pulled for free? anonymous_wolf Vancouver Impreza Club Forum -- VIC 5 08-11-2005 01:40 AM
('93-'01) CEL code ???? UU AR EX Impreza Forum 2 10-15-2001 01:23 PM
P1904 CEL code rwroth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-02-2001 01:00 PM
