Old 01-18-2004, 08:16 PM   #1
Boost4U
Member#: 16459
1998 2.5RS
Default Retaining ABS
During the process of my engine and tranny swap i have converted my AT 98 RS into a USDM WRX powered RS with a USDM WRX 5MT tranny. I want to know if there is any was to wire the ABS to work with this setup. In the schematics there is a single wire runnning from the TCU in the RS to the ABS control unit. I assume the secret lies in this wire, has anyone had any experience with it? Any tips would be appreciated!
-Chris
Boost4U is offline   Reply With Quote
Old 01-19-2004, 02:04 PM   #2
Boost4U
Member#: 16459
1998 2.5RS
I remember reading a post that talked about someone trying to figure it out.....I've search for a week and can't find it. Someone please help!
Old 01-19-2004, 02:20 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I would imagine the abs system isn't working at the moment?
In Mechanism and Function Section:
When the ABS is active, the ABSCM provides the automatic transmission control module with control signals which are used by the module for cooperative control of the vehicle with the ABSCM.
In reading that, it looks like that wire is merely an output, not an input of any sort.
Have you tried throwing your car into diagnosis mode and pulling the abs trouble code? You can also read abs codes using the SSM.
-Jon
Old 01-19-2004, 10:59 PM   #4
Boost4U
Member#: 16459
1998 2.5RS
Well...the car is not running at the moment. However I was under the impression that the ABS would not work. Whey I turn the ignition on the ABS light remains illuminated. I will be able to test them in a week or so. I guess I should get to that point first, then I'll post back on my fingings. Thanks for the info though!
-Chris
Old 01-20-2004, 11:33 AM   #5
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Mine doesn't work either. I was told by Lachute that I need an MT ABS module. It's really not that bad without the ABS, you just have to get used to it. I might replace it eventually, but as of now I don't really care. Anyone know how hard it would be to hook up a new ABS module and bleed, etc.
Oh, and I went from AT to STi engine and tranny.
garface is offline   Reply With Quote
Old 01-20-2004, 07:54 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I would say if it's not going to work to scrap the ABS stuff all together and use the non-ABS booster...much firmer feel...I like it A LOT MORE!!!...wish I still had mine
Old 01-24-2004, 09:17 AM   #7
Boost4U
Member#: 16459
1998 2.5RS
Sounds like a plan, I'd love a firmer pedal feel!
Old 01-26-2004, 01:41 AM   #8
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I'm about to swap a 1998 2.5RS 5MT into my 1999 Legacy OB. Am I going to loose my ABS? This would be really bad as it's the middle of winter and the roads are covered in snow. What parts do I need to enable ABS again?
whtlegacy is offline   Reply With Quote
Old 01-27-2004, 09:27 PM   #9
Boost4U
Member#: 16459
1998 2.5RS
I will let you know as soon I can test my swap
Old 01-27-2004, 10:48 PM   #10
Homemade WRX
Member#: 33782
96 bastard child
um whtlegacy...the tranny doesn't have much to do with the ABS...I don't think it has anything at all to do with the ABS itself...
Old 01-27-2004, 11:00 PM   #11
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I'm pretty sure I heard that ABS links into the automatic TCU. I could definately be wrong though.
Old 01-27-2004, 11:08 PM   #12
Homemade WRX
Member#: 33782
96 bastard child
It may just to disengage gears but that happens when you brake anyhow....that will go away anyway when you install the manual though...no need for it anymore
Old 01-27-2004, 11:14 PM   #13
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
well thats good news
sti lip or abs plastic wrx lip and abs plastic side skirts...painted wrb is a plus NJ M32WRXin3seconds Private 'Wanted' Classifieds 1 08-24-2003 05:17 PM
Difference between ABS and non ABS Brake Lines? AKGC8 Brakes, Steering & Suspension 1 12-30-2002 09:24 AM
ABS gurus- I have a question about messed up ABS edkwon Brakes, Steering & Suspension 4 11-01-2002 05:00 AM
ABS on Non-ABS car mhj Brakes, Steering & Suspension 4 02-13-2001 09:41 PM
Gravel roads - ABS or no ABS? 8Complex General Forum Archive 7 06-20-2000 09:35 PM
