Old 01-19-2004, 01:16 AM   #1
abqkid
Member#: 52295
2003 WRX Wagon
Default Gutted Up pipe...any problems?
Yo yo,
I was planning on gutting my stock up pipe on my o3 wrx. I was wondering if anyone has had any major problems after doing this. I know the cel can come on and that you must get all of the cat material out of the pipe...but other than that?
thanks
abqkid is offline   Reply With Quote
Old 01-19-2004, 02:16 AM   #2
skinart76
Member#: 30769
2003 WRX Wagon
Sonic Yellow
nope, none what so ever. Got rid of the EGT probe, and just went with the resistor. Car is as happy as it can be.
Stan
skinart76 is offline   Reply With Quote
Old 01-19-2004, 03:05 AM   #3
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
mexicanpizza is offline   Reply With Quote
Old 01-19-2004, 03:12 AM   #4
supermarkus
Member#: 6971
2008 WRX STi
SSM
~14K on mine and no problems yet.
supermarkus is offline   Reply With Quote
Old 01-19-2004, 09:07 AM   #5
rotorbaru
Member#: 22493
2003 Impreza WRX
Silver Cobb stg 2
If you leave the stock EGT in it will probably fail within a few thousand miles, just put in the 2.5k ohm resistor.
rotorbaru is offline   Reply With Quote
Old 01-19-2004, 11:04 AM   #6
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
yep my egt sensor failed wint in ~5000 miles..
Old 01-19-2004, 11:05 AM   #7
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
What he said ^, but 2.2k ohm.
Here's a link to the resistor mod: http://www.clubwrx.net/forums/showth...t=resistor+mod
Old 01-19-2004, 12:12 PM   #8
abqkid
Member#: 52295
2003 WRX Wagon
thanks all
Old 01-19-2004, 12:13 PM   #9
abqkid
Member#: 52295
2003 WRX Wagon
oh yeah, when you say the egt sensor fails, does that mean you get a CEL or something else?
Old 01-19-2004, 12:56 PM   #10
supermarkus
Member#: 6971
2008 WRX STi
SSM
even better, you get thrown into limp mode as well.
Old 01-19-2004, 01:28 PM   #11
jcwrx
Member#: 25989
2009 WRX Stage 2+
Lightning Red Hatchback
Default cat material removal?
What is the best way to remove the cat material. I understand the material is very toxic and one needs to wear a mask and gloves and such.
what is the best method for performing this mod to the OE cat?
Thanks for your time.
JC
jcwrx is offline   Reply With Quote
Old 01-19-2004, 02:13 PM   #12
abqkid
Member#: 52295
2003 WRX Wagon
on the stock up pipe do i just plug the bung with a bolt or somthing like that? If i dont have a resistor can i get one at radio shack or something like that? If i install the up pipe with out the resistor how easy is it to go back and install the resistor into the sensor?
yeah you should probably wear a dust mask and gloves from what i have heard. also try and drill it out in a well ventilated area.
Old 01-19-2004, 02:53 PM   #13
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
Bolt = M12x1.25
Resistor from radio shack works perfectly. The plug is located under that boost control cover. Read that thread I gave you
Old 01-19-2004, 03:00 PM   #14
abqkid
Member#: 52295
2003 WRX Wagon
yo jcwrx,
check this out
http://webpages.charter.net/baraboo_...ppipe_fix.html
that should tell you how to remove the cat
Old 01-19-2004, 03:02 PM   #15
abqkid
Member#: 52295
2003 WRX Wagon
bye the way...what causes the resistor to fail? And why would it not fail when the pipe is not gutted?
thanks
Old 01-19-2004, 09:30 PM   #16
jcwrx
Member#: 25989
2009 WRX Stage 2+
Default Tx kid
Thanks for the link.
JC
Originally posted by abqkid
yo jcwrx,
check this out
Old 01-19-2004, 09:54 PM   #17
cronic
Member#: 9749
thanks
I assume you mean what makes the Probe fail? THe probe is there to make sure egt's are within a certain degree.. WHen you run a decatted uppipe the temp changes and causes a cel.. By installing the resistor it tricks the ECU to think it is always that perfect temp.. You can install the uppipe with the stock egt probe and then later go in and remove it..
What you need to do is remove the probe from uppipe, then open up the boost control solonoid cover which is located on the pass side fender.. Follow the wire attached to the probe and locate the connector(should be the botttom connector) Un plug it. Put one end of the resistor in one opening on the plug and the other end of the resistor in the remainng hole, then tape up the end of the connector. Then remove the probe from the car all together.. Now take your bolt and nut screw the nut onto the bolt, screw bolt 1 inch into the uppipe and then tighten down the nut.. Make sure to use a 2.2kohm 1/4watt ressistor.. This job takes all of 5 min..
Dave
cronic is online now   Reply With Quote
Old 01-19-2004, 09:55 PM   #18
pityr
Member#: 31719
thanks
Hard to say but Ive burnt up 2 before I just plugged it. Some say its cause the gasses are too hot but I noitced the EGT temps lower significantly when I gutten my up-pipe.
BTWm the sensor actually fails. The EGT temps are not different enough for it to cause a CEL. The CEL comes from teh sensor not reading at all.
pityr is offline   Reply With Quote
Old 01-20-2004, 03:57 PM   #19
rex65
Member#: 34280
2003 WRX-Cobb II
Use a 2.2kohm 1/2 watt resistor. The 1/4 watt has been reported on this forum to burn out. Also, if you look at the pictue posted above it appears that the metal mesh that goes around the cat material is still in the pipe. Make sure you get everyhting out of the cat.
Dave
rex65 is offline   Reply With Quote
Old 04-02-2004, 08:30 AM   #20
gotsol
Member#: 17346
08 Cayman S
Okay, late in the discussion here, but I've gutten mine and cleaned it real well with a grinder. Used compressed air to clean out the small bits. But I get a noise when I move the pipe, like the is still metal moving around. Yet I can not get the peices out.
Anyone else have this problem when gutting a stock uppipe? I'd havte to put it in and then damage the turbo.
gotsol is offline   Reply With Quote
Old 04-02-2004, 09:51 AM   #21
vile
Member#: 32371
'02 t-rex wagon
platinum
it could be debri in between the pipe and the heat shield
vile is offline   Reply With Quote
Old 04-02-2004, 10:03 AM   #22
tjthorson
Member#: 49545
2004 WRX Wagon 5sp
Rally Blue
According to the thread posted, you should use a 1/2 watt resistor.... the 1/4 is not strong enough.....
tjthorson is offline   Reply With Quote
samco intercooler Y pipe and gutted and non gutted up pipes subrandon SCIC Private Classifieds 4 10-14-2006 11:50 PM
Gutted Up-pipe problem MarcusDubya77 Factory 2.5L Turbo Powertrain 0 07-26-2005 07:04 PM
lookin for gutted up pipe, any bellmouth 3" DP Cashie Private 'Wanted' Classifieds 2 12-05-2004 12:39 PM
Any one have a gutted up pipe they would sell? motorswapsleeper Private 'Wanted' Classifieds 4 08-10-2003 05:42 AM
Gutted Up Pipe...Any good? blindclown Factory 2.0L Turbo Powertrain 5 01-02-2003 07:11 PM
Message Board Statistics All times are GMT -4. The time now is 10:58 PM.
