Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 01-19-2004, 07:36 AM   #1
Siper2
Member#: 1134
2007 BMW 328xi wagon
Angry Oh great. On top of the CEL, now I have squealing.
My poor car.
First I get a CEL, well over a month ago, that has yet to go away.
I've lost count of the trips to Exeter that I've taken. Brian and Mike in Parts told me they should've got me my own La-Z-Boy to put out back. It's a "piston 4 misfire" and so far, here's the tally:
- Got CEL, assumed it was plugs/wires. Was overdue. Bought new ones. Went to install, found oil in sparkplug chamber.
- Replaced valve gaskets. Put new plugs/wires in.
- CEL returns. Exeter says I need a new coil. Replaced it.
- CEL returns again. Same code. Reset light. Take off CAI per Exeter's request. (Doubt that's it, but I'll humor them.)
- CEL is back. Replace fuel filter per my request, that was overdue as well. Clear light.
- Guess what? CEL returns yet again. Dropping car off today.
Brian's theory is stuck valves. I'm going to due an injector cleaning service. After that I'm not sure where to turn.
Two days ago, though, I noticed that at idle, I hear a whine/squeal from the engine. Revving a little makes it stop. (Drive belt??)
Driving to work yesterday morning, the squeal starts about 3/4 of the way there. Worse when I turn right. Stops when I turn left.
I'd think another wheel bearing's gone, but why would it do this at idle?? (When I blew my right rear bearings a few months ago, it only did the nasty squealing noise while driving/turning.) Sometimes it seems to come from the engine... sometimes it almost sounds like the REAR. (Differential??)
That and my whole gas canister, highway bumper-hole incident.
I can't handle this anymore. Plus I have to still pack to move...
-Chris
Siper2 is offline   Reply With Quote
Old 01-19-2004, 07:42 AM   #2
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Sounds to me like a power steering pump, or a power steering pump belt is slipping.
FWIW:
With the cold temps the PS pump/fluid on my Van froze last Friday, and would scream bloddy murder in the really cold temps until the car warmed up. This weekend it was fine though.
I don't think PS fluid is designed for these sort of temps.
Paul G.
paultg is offline   Reply With Quote
Old 01-19-2004, 07:57 AM   #3
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Originally posted by paultg
FWIW:
I had a similar situation last week where I would hear a light groan when turning the wheel to the left (but not right). Interesting idea regarding the fluid.
Snowphun is offline   Reply With Quote
Old 01-19-2004, 08:03 AM   #4
paultg
Member#: 437
'91 Miata MX5 (Red)
Well,
I should also disclose the fluid in the Van has ~125K miles on it, and is original from 1993 as far as I know.
I'm sure it has lost some of it's properties to prevent freezing, etc..
Paul G.
Old 01-19-2004, 10:17 AM   #5
Siper2
Member#: 1134
Paul,
Good suggestion. It's actually something I briefly considered, believe it or not, but I didn't think that could be it, if I wasn't turning the wheel. (Which I'm not when it does it at idle. It does seem that the car has to warm up some before it does it, though. And yesterday it didn't do it at all, on the way home.)
I know it could start happening at any time, but what baffles me is why it didn't do this when it was holy-frickin-cold out, several days ago. It started I think when the weather went to like 30.
How often should p.s. fluid be swapped?
Old 01-19-2004, 10:38 AM   #6
FletchMY98
Member#: 6395
2006 WRX STI
Steel Grey Metallic
CEL: A stuck valve is easily diagnosed with compression and leak down tests. A bad injector is pretty easy to diagnose from spark plug readings and OBD scanning.
Squealing: Just sounds like a loose belt to me.
Chris
FletchMY98 is offline   Reply With Quote
Old 01-19-2004, 10:48 AM   #7
Siper2
Member#: 1134
They ran a compression test, everything was perfect. So I guess the injector thing is next, I don't know. I looked back through my service records and I don't think it was done on my 60k service, so maybe that's due, as well.
(I've now officially pieced together all the things that make up a 90k service, albeit not at once. So I think that's all done... Except perhaps brake fluid. The tranny fluid I hope to swap when I do my new clutch.)
Squealing: Yeah it might be. Hopefully it'll reproduce when I get there.
Oh Great Suby Gurus of the SE forum...Cold Clutch Weirdness? Skullskidr South East Region Forum 14 01-30-2004 08:48 AM
What's the purpose of the coolant reserve tank/header tank on top of the engine? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-28-2003 01:47 PM
What is this on top of the Rally WRX? MattDell Interior & Exterior Modification 25 12-23-2002 01:32 AM
Newbie question, what is that switch on top of the steering colum? anant369 Newbies & FAQs 6 05-10-2002 08:01 PM
dust caps on top of the front struts tmat3 Brakes, Steering & Suspension 0 05-10-2002 11:11 AM
