Old 01-19-2004, 09:32 AM   #1
Steevo
Member#: 39984
Default Stock lug nuts on Subzeros?
Does anyone know if you can use your stock lug nuts on Rota subzeros? I have some 17 x 7.5 on the way and have heard conflicting answers. Any owners of these rims using the stock lug nuts?
Steevo is offline   Reply With Quote
Old 01-19-2004, 10:09 AM   #2
rexster
Member#: 22863
2015 WRX Premium CWP
I use stock lugs and Subaru locks with mine. No problems...
rexster is offline   Reply With Quote
Old 01-19-2004, 10:45 AM   #3
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
Default Re: Stock lug nuts on Subzeros?
Well, you *can* technically use the stock lug nuts, but I wouldn't. The seating area is all wrong. You need 'tuner lugs' with a more pronounced conical taper. I use these from Suby Dude and they work great:
Good luck,
Scott
sdecker is offline   Reply With Quote
Old 01-19-2004, 11:17 AM   #4
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
Scott: Do you know where to get black versions of these?
Subahaulic is offline   Reply With Quote
Old 01-19-2004, 11:19 AM   #5
sdecker
Member#: 14717
2002 WRX, WR Blue
I'm almost positive Suby Dude carries them in black...did you try his web site? If you don't see them, shoot Joe an e-mail. If he doesn't have them, he can surely get them.
Scott
Old 01-19-2004, 01:25 PM   #6
Steevo
Member#: 39984
What is the benefit of the conical lugs? If you *can*as you say, use the stock ones, what is the detriment? Do you just use the conical ones for peace of mind? I would like to know the specific reasons because if the stocks will work without problems why would anyone buy aftermarket? Just looking to keep the stockers unless there are any verified problems with doing so.
Old 01-19-2004, 01:43 PM   #7
sdecker
Member#: 14717
2002 WRX, WR Blue
Well, the stock lug nuts will still fit on the studs and thread all the way down to the wheel...so they still technically 'fit'.
Put one of your Subzeros and one of your stock rims on the ground next to each other, and place a factory lug nut over a single hole on each. Take a close look at the interface between the two lug nuts and wheel surfaces and you'll see what I'm talking about. The angles are all wrong.
You might be perfectly happy with the stockers. I track my car a lot and I wanted a lot more surface area than the stockers provided on my Subzeros, but then again that's just my opinion.
And as to why someone would want to go aftermarket, there are lots of other reasons besides fit. Weight, exotic materials, color, locking, splined, open ended, etc. are all good reasons. Those duralumin ones above are super super light, which is why I like them...along with the fact that they don't rust like the POS stock ones.
Gluck...
Old 01-19-2004, 03:43 PM   #8
Steevo
Member#: 39984
Ok...that being said, disregarding appearance there is really no functional reason to replace the lug nuts? I could care less about the look and weight of my lug nuts. As long as they are going to thread all the way down I'll be happy. If anyone has had a functionality problem due to the stock nuts, please let me know.
Old 01-19-2004, 04:22 PM   #9
sdecker
Member#: 14717
2002 WRX, WR Blue
Good luck -- hope the stockers work out for ya.
Old 01-19-2004, 05:51 PM   #10
Subahaulic
Member#: 51163
Another reason I was given is that stockers will do some damage because they lack the rotating collars of McGard's, as an example. This might only be a consideration when reselling the blemished/gouged wheels. That said, I am having a bunch of trouble buying a set of these "sold-out" lugs.
Mark
tappered lug nuts on stock wheels? 05ASPINREX Tire & Wheel 2 10-24-2008 12:53 PM
Gorilla spline drive lug nuts & stock lug nuts Boosted Up Wheels/Tires 5 07-10-2008 11:45 PM
Gorilla spline drive lug nuts & stock lug nuts Boosted Up TXIC Private Classifieds 5 07-06-2008 11:33 PM
My Stock Lug Nuts Suck On My New Wheels??? EjMiami Tire & Wheel 8 05-28-2006 03:19 PM
Stock Lug nuts for SUBZEROS? 02WRX_BLUE Brakes, Steering & Suspension 2 01-10-2003 01:29 PM
