Old 01-19-2004, 11:06 AM   #1
senomar
Member#: 47636
01 rsti v7
blue
Default HVAC Dead! I'm freezing.
got my car a couple days ago (01rs with ej20), and had great heat for that time period. then this morning when i came into work, NOTHING! air wasn't even blowing... and it's like 0 degrees here in Chicago... so is there a fuse or something simple that might have come loose? i'm probably just gonna take it in, but thought i'd ask here first to see if it's possibly a common problem in swaps.... thanks guys.
cody
senomar is offline   Reply With Quote
Old 01-19-2004, 11:55 AM   #2
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
many things can go wrong. I have all parts taken apart if you want to see. no air blowing at all eh. I would check fuse first. The the plugs. There are um 2 plugs I believe. Sorry I am real tired I will answer this later. ZZZZ time be back in couple hours!
AWJunkies is offline   Reply With Quote
Old 01-19-2004, 12:04 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I had this problem too. Turned out, I didn't have the blower connector in. Check your fuse and if that is ok, pull your glovebox and check your connector at the blower. If the connector is there, start checking voltages to make sure it is getting to the blower.
As AWJunkies said, there are two conenctors there. The upper connector should be to your A/C evap temp sensor and the lower one should be your blower motor.
-Jon
Old 01-19-2004, 02:28 PM   #4
senomar
Member#: 47636
01 rsti v7
blue
Default reply
where are the plugs you guys are referring to? i checked the fuses, and they seem to be fine. thanks for the help, i just need a little more so i can stop freezing.... thanks guys!
cody
Old 01-19-2004, 02:52 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The plugs are on the blower motor assembly behind the glovebox. They are kind of obvious with that removed. If I remember correctly, there should not be any disconnected plugs on that side, in that location.
-Jon
Old 01-19-2004, 03:09 PM   #6
senomar
Member#: 47636
01 rsti v7
blue
Default thanks
thank you sir. i'll check those out this afternoon.
can they come unplugged easily? cuz like i said, everything was fine the last 2 days, and now...well, yeah...
anyway, thanks again to all you guys out there who hang out on these boards to help us dummies out. hopefully one day i will have some knowledge to share as well...
cody
Old 01-19-2004, 10:08 PM   #7
senomar
Member#: 47636
01 rsti v7
blue
Default update!
hey guys... just thought i'd give a quick update in case anyone cared... well, i'm no mechanic by any stretch of the imagination, but i managed to fix my problem by pulling back the carpet and pushing all the wires i could find a little more snug into their harness. ::side note-my car has a utec, and there are wires all over the friggin place down there:: in any case, started the car back up and by some miracle, i have blowing air with heat! i couldn't figure out what the blower motor was, so i just made everything a little more snug. i guess that did the trick.
question though... does the UTEC have anything to do with the HVAC controls? i don't know what i did, but it worked, so i'm happy as long as this doesn't keep hapening every day...
thanks again guys
cody
Old 01-20-2004, 07:56 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
well my AC doesn't work from the swap and it gets hot and super humid here
Old 01-20-2004, 08:18 PM   #9
senomar
Member#: 47636
01 rsti v7
blue
that would definitely be worse. why don't you fix that? or have it fixed somewhere? can't be too difficult. not that i would know.
well the new update with my heat is that it comes and goes.... i think it's gotta be the blower wires that are loose, cuz when i push around the wires a little bit (the UTEC and any others i can touch), it tends to come back.... this sucks. i'm taking it in for a couple other things, i'll have them look at this too....
later
cody
Old 01-20-2004, 09:42 PM   #10
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
blue ridge pearl-sold
Sounds like your rs was ghetto rigged,welcome to the club
imprezaclipse is offline   Reply With Quote
Old 01-20-2004, 10:55 PM   #11
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
hey senomar wanted to ask. Little off topic, but who did your swap? Anyone in the area? Looking to possably do one by the summer. Just curious thanks
Andy
AndyM is offline   Reply With Quote
Old 01-21-2004, 01:23 PM   #12
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Did they run the blower and stuff off the Integrated Unit or is it apart from the WRX wiring? If it is part of the Integrated Unit, then that was unnecessary. If it is apart from the WRX wiring, then it should be fine
If you paid to have it done then take it back and have them fix it. Nothing should be intermittant because that indicates a broken plug, bad soldering job, or a cut wire.
-Jon
Old 01-21-2004, 02:39 PM   #13
senomar
Member#: 47636
01 rsti v7
blue
Default reply
jon- what do you mean by "integrated unit"??? are you talking about the UTEC here? I don't quite understand what you mean.
i am the 3rd owner of this car since it's been swapped. the swap was done by people at Prestige Subaru in South Carolina. They have a good reputation from what i've read, but this car definitely seems to be somewhat "ghetto-rigged".... should be a fun time.
Old 01-21-2004, 02:50 PM   #14
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
It is a mini-ECU of sorts in the WRX that controls miscellaneous functions like rear defrost, HVAC, and a couple others I think. I bypassed mine and used the existing wiring configuration for those functions.
-Jon
Old 01-21-2004, 03:46 PM   #15
senomar
Member#: 47636
01 rsti v7
blue
Default ..
where would this be located if it's there? sounds like it's nowhere near the computer...???
Old 01-21-2004, 05:04 PM   #16
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Could be anywhere. It was on the driver's side on the WRX. Might not even be in there...
-Jon
Old 01-21-2004, 05:08 PM   #17
senomar
Member#: 47636
01 rsti v7
blue
fantastic... well, thanks for all your help on this chilling issue. looks like i may have to learn something about my car now! dammit. i'll report back anything i find out. thanks again jon, and everyone else.
cody
Old 01-22-2004, 06:53 AM   #18
senomar
Member#: 47636
01 rsti v7
blue
Default f
last post on this thread, i promise... do you think if i take it to a subaru dealer that they will be able to fix this problem?? i know the heat works, the blower just goes on and off.... so frustrating!! i'm sick of trying to fool with wires, and just want it fixed. so what do you guys think? would that be the best place to take it?
Old 01-22-2004, 12:04 PM   #19
AndyM
Member#: 3219
WR Blue Pearl
Well senomar since your in the Chicago area we have dealerships, but what Im trying to say is most around the area suck. I havent met one person that has been happy when taking their car to the dealership. Some places that come to mind are Schaumburg Subaru and ROTO Subaru. Ask the guys in the MWIC forums and see what they say.
Old 01-22-2004, 05:21 PM   #20
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
Hit it with a hammer,a big one.
HVAC dead nJDMmaster Service & Maintenance 5 07-08-2008 09:04 PM
Damn, now I'm freezing and have to go dig out a sweater! Janq Off-Topic 53 06-16-2005 01:05 AM
I'm freezing! awdity Off-Topic 55 07-08-2004 01:45 PM
HI! I'm not dead, I'm in Nashville! WagonMonster Off-Topic 21 04-15-2004 09:29 PM
I'm FREEZING!! bruticus Off-Topic 15 03-22-2004 04:15 PM
