Old 01-19-2004, 12:09 PM   #1
leecea
Member#: 37359
2003 WRX
Default Burning rubber smell
Over the last couple of days my car developed a very slight burning rubber smell every time I go out for a few miles of relaxed driving. I found one other post that seemed related but with no answers.
Any ideas before I start searching?
Thanks.
Edit: all stock except a) Koni inserts added months ago, b) AC in defrost mode disconnected ages ago.
leecea is offline   Reply With Quote
Old 02-02-2004, 08:18 PM   #2
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
There's a good chance you're smelling oil burning, not rubber.
vrg3 is offline   Reply With Quote
Old 02-03-2004, 04:34 AM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
You might want to take a quick look under the hood and make sure no hoses have gotten loose or misrouted near hot parts of the engine.
Old 02-03-2004, 10:30 AM   #4
leecea
Member#: 37359
2003 WRX
Thanks all. After my first post I looked as extensively as I could in the engine compartment and under the car. Nothing seemed wrong with any hoses and there was no sign of any fluid leaks. I haven't smelt anything since then. I have no explanation but it seems to have gone away!
Old 02-03-2004, 10:46 AM   #5
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
You may be starting to develop a small leak. It's not uncommon for a valve cover gasket to leak a little bit of oil directly onto the exhaust. It burns right away, so you don't see it collect, and it smells similar to burning rubber.
Old 02-03-2004, 01:07 PM   #6
z&cobb
Member#: 12344
2002 2JC
blue
If all else fails, inspect the right front inner axle boot. Look for grease on it. If there is a small crack in the boot, it can sling grease on the exhaust.
z&cobb is offline   Reply With Quote
Old 02-04-2004, 01:43 PM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
you could have had a plastic bag/road debris
land onto your exhaust, and then burn itself off
happens all of the time
Jamie
www.subiegal.com
Old 02-04-2004, 04:22 PM   #8
leecea
Member#: 37359
2003 WRX
I like that theory better than the others since it doesn't require me to try and fix anything
Old 02-04-2004, 07:02 PM   #9
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
if it returns -
jack the car up and take a good, thorough look underneath.
burning rubber smell on my rs
turned out to be leaking axle seals
but the scent was consistent
and eventually i could see the leaking fluid.
but this took several days....
good luck!
Jamie
Burning rubber smell from front of the car Scott4DMny Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-23-2005 12:08 AM
burning rubber smell!!! djplayboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-07-2004 05:16 PM
burning rubber smell 04Scooby_Rex Tire & Wheel 13 09-20-2004 08:44 AM
New Borla headers w/burning rubber smell? spshultz Normally Aspirated Powertrain 9 11-19-2000 03:33 PM
