Old 01-19-2004, 12:40 PM   #1
Rossi
Member#: 37618
96 L
Red
Default Tachometer conversion
I have 96 Impreza MT without a tachometer. How should I go about putting one in? Can i just get a gauge cluster out of a car with a tach and swap it in?
Does my car have the cable for the tach already running to the dash and its just not plugged into anything?
If i can just use another gauge cluster, does it have to be the same year, or can I get a newer one?
-Rossi
Rossi is offline   Reply With Quote
Old 01-19-2004, 02:03 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I would imagine you would be able to use any of the gauge clusters from 93-96. Just make sure your ECU has the engine speed output pin before proceeding (I can't imagine why it wouldn't). You will just have to get a wire up to the gauge cluster and you will be golden; if you are lucky, the wire is already there, just not in use.
-Jon
Old 01-19-2004, 03:44 PM   #3
Rossi
Member#: 37618
96 L
Red
just looked at a service manual for my car. The wiring diagram shows no wire for the tachomoter for years 95-96. There are wires for the tach for earlier and later years though. Any one have any ideas about this?
-Rossi
Old 01-19-2004, 04:04 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
You can swap in a cluster that has a tach. It'll work jus-fine!
Before I swapped a new cluster in, I added a tach to where the OEM one should be. The terminals are right there on the circuit trace to tap into. Takes a couple hrs to do if you're working slow and methodical. Only about an hour to swap the cluster...unless you want to keep your original speedo/odo.
Beware of when SOA went to electronic speed sensors. You'll have to account for that if you still have a speedo cable.
Jay Storm
www.sourcemotorsports.com
7k RPM tachometer to 8k RPM tachometer swap - any idea what's involved? Patrick Olsen Subaru Conversions 8 08-04-2007 10:05 AM
('93-'01) HELP!! installing autometer tachometer r1racing Impreza Forum 3 05-04-2001 08:08 PM
HELP!! installing autometer tachometer r1racing Normally Aspirated Powertrain 0 05-04-2001 02:01 PM
WTB: MY99~01 white Tachometer AND Speedometer yuusaku Vancouver Impreza Club Forum -- VIC 0 05-04-2001 12:23 AM
('93-'01) i need a tachometer DoinkMobb Impreza Forum 11 04-27-2001 12:25 AM
