Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 01-19-2004, 05:30 PM   #1
serious
Member#: 22879
Default Removing abs from a legacy
Hi all, another removal question. I would like to remove the abs braking system in my 96 legacy. Is this simple as removing all the old brake lines that are abs and the abs motor/solinoid and replacing with non abs parts?
I know you have to pull up a bunch of stuff on the passenger side of the car to even get at the line, but it will be apart for my engine conversion anyway. I also know there is a bunch of extra wiring involved that should be removed also. If i removed the abs wiring from the car, would this bring up any issues with anything else in the car. (stuff like the ecu being dependant on the input from the abs etc...???)
Thanks
Brent
serious is offline   Reply With Quote
Old 01-20-2004, 02:30 AM   #2
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default answer
I might ask the question why remove it. But anyways just pull the ABS fuse. Tada no ABS. some people hook up a switch so they can turn it on and off at will. Do a search or checkout www.scoobymods.com I believe the exact sets are there. Either way they are around some where.
Joshua
yebokmj is offline   Reply With Quote
Old 01-20-2004, 05:10 PM   #3
serious
Member#: 22879
I've always wondered if you could just pull the fuse or unplug it and have it work like no abs. I am thinking about installing a set of brembos front and rear and i don't know if it would be compatable with it or not.
Brent
Old 01-20-2004, 08:49 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
um the calipers don't make a difference really as far as ABS goes...the sensor notices the wheels have locked up the actuator starts pumping the brakes....put simply...
WTB: ABS unit from 1995 Legacy splicesite Private 'Wanted' Classifieds 1 11-16-2009 12:03 PM
easiest/cheapest way to remove ABS from 02 wrx? skate enjoi Brakes, Steering & Suspension 2 07-18-2008 01:40 PM
How to remove mailing tape from a legacy higgins14 Car Care & Detailing 6 02-18-2008 07:12 PM
Remove tint from rears only or remove from all windows gooder77 Interior & Exterior Modification 6 04-02-2007 06:02 PM
Removing entire ABS from MY00 RS... what is involved? mpaone Brakes, Steering & Suspension 9 04-02-2005 04:50 AM
