Old 01-19-2004, 07:43 PM   #1
MRTimpreza
Member#: 36371
2012 STI hatch
Default need fenders rolled
I was wondering if any one knows or if any one does fender rolling . I need my fenders rolled on my suby so i can stop hearing my tires hit my fenders everytime i hit a bump. If anyone can help it would be great so i can get this done real soon so i can actually drive my car like it is supposed to be. Thanks alot.
MRTimpreza is offline   Reply With Quote
Old 01-19-2004, 08:25 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Given any thought to putting the right size tires and wheels on it ?
Brian
Old 01-19-2004, 09:01 PM   #3
azimiut
Member#: 43426
2002 Aspen White WRX
STI Swap Dynocomp tuned
what size tire/wheel combo do you have? I had 225/35/19 with 1.5 drop and they fit. BTW, they are for sale
azimiut is offline   Reply With Quote
Old 01-19-2004, 09:32 PM   #4
Takashi
Member#: 2536
2012 STi Hatch
Brian
what he said... if you're offset is way off, you may have to deal with wheel bearing problems down the road.... i've never heard of an sti needing it's fenders rolled.
greg
Takashi is offline   Reply With Quote
Old 01-20-2004, 04:29 PM   #5
The Donnn
Member#: 33178
SQC 106
how about someone just answer the guys question
The Donnn is offline   Reply With Quote
Old 01-20-2004, 04:39 PM   #6
Takashi
Member#: 2536
2012 STi Hatch
i'm just saying that rolling the fenders may be a temporary fix. the real problem may be that the wheels are not the correct size/offset. in which case he could have problems down the road. maybe not... and i'm not trying to bust his balls or anything, just trying to help.
oh, and mrtimpreza, it would probably be more effective to post this question in your regional forum so that you can find someone to do this in your area.
greg
Old 01-20-2004, 04:58 PM   #7
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Heat up your fender and roll them with a baseball bat. There simple answer.
Though I dont see a need to run a wheel tire combo on the street that needs fender rolling to fit I am going to have to roll mine to fit my autox tire/wheels in there.
afpdl is offline   Reply With Quote
Old 01-21-2004, 08:50 AM   #8
Tire Rack Moderator
Member#: 1215
ext. 4362
most body shops can do it ....
Old 01-21-2004, 07:40 PM   #9
MRTimpreza
Member#: 36371
2012 STI hatch
I know that i definately have the right offset. It is just that the wheels are wide. I am running 8.5" wide wheels. So if anyone does this let me know cause i tried calling some body shops and asked if they rolled fenders and they immediately said no. Any help would be great.
Old 01-21-2004, 08:01 PM   #10
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
I just did it with a baseball bat and a hair dryer yesterday. It worked fine just take your time.
And they said get a properly sized wheel tire combonation not just that you had the wrong offset. If 8.5s dont fit then they dont fit.
Old 01-21-2004, 09:01 PM   #11
riverarob
Member#: 44973
2003 WRX
Any place that sells custom wheels & tires would be able to roll the fenders. I've seen it done at a local wheel/tire store. They remove the wheel and attach the tool to the hub using the same holes where the lugnuts go. A heat gun is used on the inner edge of the fender to heat the area and then the tool is rolled right across the inside of the fender. If you can't find a place then
afpdl filled you in on the DIY option. He wasn't joking, it'll work.
riverarob is offline   Reply With Quote
Old 01-21-2004, 09:38 PM   #12
ej20love
Member#: 48520
2002 JDM WRX STi Ltd
PSM, Ducati
im having the same pronblem. I'm running a 17x8.5 with 245/40-17 tires and it is not dropped. If 4 people are in my car, i will hear it hit the fender if I hit a bump..... It looks dope though, should be easy to roll them though.
ej20love is offline   Reply With Quote
Old 01-22-2004, 04:08 AM   #13
datwrx
Member#: 17821
2002 Subaru wrx
candy apple red
I'm running 17 by 8 and I have the same problem. I already had it rolled and it doesn't rub anymore. My friend help me do it with a large pipe. I heard Sprewell racing will do it. They have the machine or some equipment to do the fend roll. They are in San Gabriel on San Gabriel blvd. You should take it there I heard they do a really good job. I should of taken it there. I would if I had an STI.
datwrx is offline   Reply With Quote
Old 01-22-2004, 07:35 PM   #14
MRTimpreza
Member#: 36371
2012 STI hatch
see i could rent that tool that goes on you hub for $75 but i just don't have the patience to do it. I would rather have someone who knows what they are doing and have plenty of experience.
Old 01-23-2004, 12:49 AM   #15
Stang2WRX
Member#: 35899
'03 Cobra
Sonic Blue
sorry, i guess this is newb..
I'm assuming "fender rolling" is rolling out the sheet metal a little to get a wider fender effect.. is this accurate? Also... with the DIY, does it come out right... what about paint problems?
take it easy on me.. im just guessing..
Stang2WRX is offline   Reply With Quote
Old 01-23-2004, 01:32 AM   #16
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
No its not actually making the fenders any wider.
If you look at your rear fenderwells you will see a rubber strip. If you take off the rubber strip you will see a peice of metal about a half inch long that goes towards the tire. Fender rolling is just rolling this strip up untill your tires stop hitting it. So basically you are just flattening out the metal in the rear fenders.
The part you are working with cant be seen from the outside the only visible change in the car woudl be the lack of the black strips around the wheel wells. I didnt have any paint cracking but If I did I doubt I would ever notice it.
Need Fenders rolled! TimChick10 Mid Atlantic Impreza Club -- MAIC 13 09-04-2008 12:47 AM
Need fender rolling anybody know a spot binyellow Southern California Impreza Club Forum -- SCIC 4 10-08-2007 10:36 PM
Need fenders rolled near West Chester Willie Dynamite Tri-State Area Forum 14 04-13-2007 12:06 PM
Need Fender Rolling Bad huckedup16 Tri-State Area Forum 12 03-26-2003 07:54 AM
Need fenders rolled dannyboy7 North West Impreza Club Forum -- NWIC 1 04-26-2001 10:30 AM
