![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 16350
Vehicle:B7 S4 Avant |
Anyone know a good one? My jack no longer fits underneath my car so someone suggested an aluminum one.
TIA
#2 |
Member#: 634
TXIC
Vehicle:2000 Impreza 2.5RS DSP#195/ZzyzxMotorsports |
#3 |
Member#: 10441
BAIC
The Harbor Freight aluminum jack isn't that low, so it might not work for your purposes. I'd love to get my hands on an AC Hydraulic DK13HLQ (see here). If that can't fit under your car, you have problems
#4 | |
Member#: 5961
South East
Vehicle:2005 STi CGM |
Not that low at all (I have one).
VV Quote:
#5 |
Member#: 10279
Vehicle:2005 Lotus Elise Yellow, #94 SS |
And it's listed at 85lbs!
I also have the Harbor Freight one, and I'm very happy with it. |
#6 |
Member#: 5961
South East
It's more on the lines of 37 lbs. Very light for a floor jack. Quality actually looks quite nice. My main complaint is that it requires a lot distance up/down to move the jack. I don't mean # of pumps until max height...it is like 4x quicker than my other floor jack in that respect, but with handle fully depressed (like working in a tight situation), it will not jack with subtle movements.
VV |
#7 | |
Member#: 10279
#8 |
Member#: 39600
RMIC
Vehicle:2008 STi (Dark Gray) 2004 FXT (Gold) |
I am also looking for a jack for autox use and have a couple quetions:
I assume these break down so I can fit them in my car? Also, how low does the harbor freight jack go? I notice the min saddle height is 3" but I assume the frame itself it higher? FWIW, my STi has about 4.5" of ground clearance right now. The harbor freight jack seems like a good deal, but I want to make sure it will work for me. -Nick |
#9 |
Member#: 35455
SCIC
Vehicle:07 LGT Spec.B DGM |
Man, I wanna get my hands on one of those AC D13HLQ's, but $382's pretty spendy. Maybe I'll be able to swing a DK20Q soon...
#10 |
Member#: 18338
Craftsman also makes a new aluminum jack. Looks similar to Harbor Freights jack but has a 4,000 lbs. max weight rating.
#11 |
Member#: 5961
South East
The Craftsman Jack is made by the same people. Mine is actually Branded "Crew Line"...you pay more for the stickers I guess. Same Jack, Same company. The Craftsman is their heavier duty model. It looks nice too.
Ground Clearance: The puck itself gets pretty low, but the body of the jack is just as tall as any other jack, and the thumbscrew that holds the handle in place is in the dead center, making it that much taller when the handle is fully depressed. So if your jack target is near the outer edge of the car, it will work at 3-3.5", but if it is in the center of the car, you better have 6" or so of clearance. VV |
#12 |
Member#: 10279
Just as one data point for the Harbor Freight jack: My car is lowered about 2" in the front, less than 1" in the rear. I can jack it up from the side (which is what I mostly do) without a problem. I can also jack it up from the rear (diff protector) directly, not much room to spare, but it works. It's been a while since I jacked it up from the front (jack plate behind oil pan), but I believe I needed to drive it on a couple of boards first.
#13 | |
Member#: 5961
South East
FWIW, I can't use it to jack my car from the front and my car is at stock height.
#14 |
Member#: 24472
Vehicle:2001 Miata White |
I have the Harbor Freight aluminum jack. I lowered my car w/ Eibach springs. I can no longer jack up the front end using the plate under the front subframe. That is unless I drive onto ramps to lift it up a bit. The high part of the jack wedges under the plastic skid plate thingy and there's no room to move the jack handle. I ended up making a pair of wooden ramps out of 2 x 6s.
#15 |
Member#: 13643
SCIC
Vehicle:'02 WRX Sdn WRB '05 Leg GT Ltd Wgn Black |
costco sells a jack that looks identical to the harbor freight one for $70, and if you don't like it 5 years down the road you can return it. Love costco!!
#16 |
Member#: 39600
RMIC
FYI, the harbor frieght jack is on sale right now for $10 off. I just picked one up.
#17 |
Techno Sapien
Moderator Member#: 449
Vehicle:2010 Legacy 3.6R Lim Azurite Blue Pearl |
Me too just now
only 5.95 more for shipping |
#18 |
Member#: 3887
Vehicle:08 Taco, 98 M3/4/5 '00 RC51, '08 KTM |
Yes, there is a sale going on for these things...
Check this thread for details: http://forums.nasioc.com/forums/show...hreadid=496359 |
| Thread Tools | |
| Display Modes | |
| Aluminum Racing Jack | Prod | Off-Topic | 68 | 10-01-2010 08:40 PM |
| FREE - Harbor freight aluminum race jack | captain_dingaling | SCIC Private Classifieds | 3 | 03-29-2008 10:52 PM |
| Aluminum Racing Jack issues | FTD | Newbies & FAQs | 8 | 10-25-2007 08:36 AM |
| Aluminum Racing jack at Harbor Freight tools for $90!! | newscooby | South East Region Forum | 11 | 02-27-2004 02:36 PM |
