Old 01-20-2004, 01:10 AM   #1
Seeing StaRS
Member#: 5294
Default Clutch "sticking" in cold weather
Any body had this problem in their GC8? I own a 2k RS coupe with roughly 5k miles on the "improved" OEM clutch. As winter set in and the temperature kept dropping I noticed subtle, then far more drastic changes in the clutch operation. I first noticed that the car would not always run when I turned the key...it would run for a second and then die. Eventually I could get it running but no sooner did I let out the clutch the revs would start to drop and want to stall the engine.
Eventually I started to put two and two together and realized that something was definitely up with the clutch. One particular night it was so bad, I had thought the temp wasn't low enough to have problems and quickly let my foot off the clutch after starting the car [in neutral mind you] and I actually felt the entire car lurch forward. I quickly grabbed the stick to ensure that yes it was in neutral. Then to my disbelief I discovered I could modulate the clutch so far as I could move the car forward as if in gear.... only I wasn't at all, I was in neutral!!
So what gives? Anyone else encountered this problem? I tried leaving it at the dealership but they could not reproduce the problem. I'm open to suggestions, I hate dealing with this problem everytime the car has sat in the cold.
Seeing StaRS is offline   Reply With Quote
Old 01-20-2004, 08:42 AM   #2
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I got no real idea here - just a guess. I'd say you have tranny or -hopefully- tranny FLUID issues.
How cold is cold there?
1 Lucky Texan is offline   Reply With Quote
Old 01-20-2004, 10:01 AM   #3
evo2rex
Member#: 40843
w/ 07 6mt DCCD Pro
Try switching to a thinner tranny fluid?
The clutch on my 02 WRX sticks when its real cold out and revs drop when I drop it for the first time.... I guess its "normal"
evo2rex is offline   Reply With Quote
Old 01-20-2004, 11:40 AM   #4
Siper2
Member#: 1134
2007 BMW 328xi wagon
Yes it's normal. I'm in New Hampshire, and last week when it was -8 and -35 with the windchill, everyone had car problems.
It's totally normal and something everyone in the world just has to live with. Anything mechanical is going to have trouble in temps like that!
You can definitely swap out for thinner, "cold weather" tranny fluid. That will of course help, just as 5W-30 oil in the cold months is much better than 10W-30. (I have 5W in my car, but no different trans. fluid yet. So my car did the same "lurch" when I took it out of gear. Everything simply got stuck when it was that cold.)
The best thing is to just not put the car in gear, when it's cold out.
I usually keep the car in 1st (or reverse) when parked, and keep the e-brake on. But when it's this cold, I just use the e-brake and keep the car in neutral.
-S2-
Siper2 is offline   Reply With Quote
Old 01-20-2004, 01:09 PM   #5
balajc
Member#: 15393
MY00 2.5RS Coupe 5MT
Silverthorn Metallic
My clutch did not stick, but the movement of the clutch pedal was really really mushy when started cold in the morning (2-5 degrees?)
also when I shift from 1st to 2nd, the rev would not drop for a couple seconds (once I clutch in). But all these symptoms are cured as soon as car warmed up
like others have mentioned, everything mechanical will start to have little problems under such cold temperature
balajc is offline   Reply With Quote
Old 01-21-2004, 12:42 PM   #6
Seeing StaRS
Member#: 5294
Thanks for the replies thus far, anyone else?
Old 01-21-2004, 12:58 PM   #7
Oldskool
Member#: 20349
1998 Impreza GME/6
Brilliant Red
I've never had the car jump/lurch, but I must say that I get horrible clutch shudder when my car isnt warmed up adequately as well as the rev not dropping very quickly. But it is kinda of nice to be able to feather the clutch and idle my way along w/o giving any gas.
All of this quits when the car is warm.
Oldskool is offline   Reply With Quote
Old 01-22-2004, 03:12 PM   #8
aliengti
Member#: 30639
'01 Silver RS Coupe
Yeah last week when it was bitter cold. I was leaving work, so I get inmy car to start it up, and after a few minutes of letting it warm up I started to get going and I noticed that the shifter was really rubbery and stiff. Not smooth and linear like I had driven it when I left the house in the morning (Car is kept in garage with heating)
So yeah it's amazing what some blistery cold weather will do.
aliengti is offline   Reply With Quote
Old 02-09-2004, 08:17 PM   #9
Farabomb
Member#: 36534
96 GC8 Panda L
00 GM6 Silver
I use lucas oil additive and a thicker than stock oil in my L and yes on really cold days I can move the car in neutral. It's the really cold, thick oil that is doing it. In fact I have to warm up the car in order to have second gear. If it's cold it won't shift 1-2, 1-3's ok but no 2nd.
Farabomb is offline   Reply With Quote
Old 02-10-2004, 06:21 PM   #10
Jazz95
Member#: 4600
Da Ridge
Racer
Damn Joe,
Do the woes ever cease? On the subject note, I have serious clutch shudder in the cold, but no stalling. I park my car outside too, and I leave for work at the buttcrack of dawn. But, after a few minutes at regular idle (this car warms up faster than any car I've ever driven), she's fine.
Your car seems to be giving you a whole lot of problems lately. Move to Florida...warm weather.
J
Jazz95 is offline   Reply With Quote
Old 02-10-2004, 11:27 PM   #11
dugrant153
Member#: 22505
1985 Old
Rusty
Wasn't there a clutch recall that dealt with these issues?
dugrant153 is offline   Reply With Quote
Old 02-11-2004, 12:38 PM   #12
Seeing StaRS
Member#: 5294
Heh, tell me about it. I found an inch of water in the spare tire well of my trunk yesterday
Farabomb,
I'm glad to hear its not just my car that refuses to go into second on cold mornings. God is that a pain in the butt.
people who commute on a motorcycle in cold weather and complain about being cold cnw Off-Topic 51 10-20-2009 02:09 PM
Brake and Clutch Pedal Sticking in Cold Weather alexk243 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-31-2008 09:52 AM
Stuck clutch pedal in cold weather? ASpec818 Transmission (AT/MT) & Driveline 4 12-26-2007 08:30 PM
Mazda Hydrogen Vehicle Takes Part in Cold Weather Testing in Hokkaido, Japan NYCshopper Non-Subaru News & Rumors 1 02-20-2007 10:50 PM
Stiff brake and clutch feel in cold weather? banman Service & Maintenance 3 01-08-2004 03:37 AM
