Old 01-20-2004, 09:04 AM   #1
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Default A/C Compressor disabled in cold climates?
I was messin around this morning and noticed when I went to the defrost position the A/C light did not illuminate nor did the cooling fans come on or did that normal slight engine surge occur when the compressor kicks on.... curious I switched to floor and vents then pressed the A/C button, the light illuminated but still... compressor didn't come on, is this normal behavior? it's about ~12 degrees F in my area, was in my garage at the time so that's around ~30 prolly.... never owned a car that disabled the AC compressor when the IATs were really slow, so i'm kinda like hmm
overdose is offline   Reply With Quote
Old 01-20-2004, 09:33 AM   #2
Kamen
Member#: 49217
2002 Impreza WRX
On either of my Legacies the A/C will turn on regardless of the outside temperature. I'm in Michigan as well so this has been tested in really cold weather. I'll do another test today (it's 12F bellow outside) and if it does not turn on I'll post another message.
Kamen
Kamen is offline   Reply With Quote
Old 01-20-2004, 09:35 AM   #3
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
The AC light never turns on when you're on Defrost.
As for the compressor being disabled when it's cold, I don't think that's the case.
heffergm is offline   Reply With Quote
Old 01-20-2004, 10:01 AM   #4
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
oh, maybe it just doesn't need to turn on yet and i didn't wait long enough?
Old 01-20-2004, 03:50 PM   #5
fredj
Member#: 13735
2002 Outback Sport
Sedona Red
I believe there is a preasure switch some where on the cooling systen that keeps it from comming on at temperatures where it would otherwise dammage it self by pushing a slug of liquid back to the compressor.
Fred
fredj is offline   Reply With Quote
Old 01-20-2004, 09:37 PM   #6
Kamen
Member#: 49217
2002 Impreza WRX
So I did the test: the compressor never moved. It was 10F outside so I guess when it's too cold it won't turn on. I have seen this work many times before but it had never been that cold - maybe above freezing. My compressor works just fine so there has to be some protection mechanism.
Kamen
Old 01-21-2004, 12:58 AM   #7
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
There is a temperature sensor in the system. This is why your compressor will kick on and off during the summer. The temperature will reach a threshold and then shut off, warm back up and turn on. etc.
-Chav
Chav is offline   Reply With Quote
Anyway to disable the Auto climate control in 2010 WRX? jay25RS Interior & Exterior Modification 7 02-23-2010 09:39 AM
Very cold climate - concerns? Tea cups Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-04-2008 11:17 AM
How bad is it to use 80w-90 in cold climates?? WRXSleeper Transmission (AT/MT) & Driveline 10 01-27-2006 12:10 PM
to those in cold weather climates (clutch problem)... shukes24 Normally Aspirated Powertrain 5 11-18-2000 06:13 AM
