Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 01-20-2004, 12:44 PM   #1
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Default Looks like I need to get out the baseball bat
And do some fender rollin. Anyone got any tips or want to help?
afpdl is offline   Reply With Quote
Old 01-20-2004, 01:15 PM   #2
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
Default Re: Looks like I need to get out the baseball bat
you need a heat gun... if not, you will crack the paint...
I have heard you leave the tire on and just roll the bat over it, and go all the way arount the fender...
I take it you got the new tires?
DanzBorin is offline   Reply With Quote
Old 01-20-2004, 05:01 PM   #3
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Damn I took out the rubber strip(ok it kind of took itself out) and Im still hiting on that metal intrusion but no where near as bad as it was with the rubber strip. Looks like I may have to start on it tonight
Old 01-20-2004, 06:19 PM   #4
jamesohoh7
Member#: 39070
GTF off my lawn!
Ya know, I read the title to this thread, and thought "Hmmm.. Alex is REALLY fired up to help Blugin find the perps who dinged up his car!"
Little did I know he was going to go all medieval on his -own- car
( I have no helpful advice in tasks like this, zero-experience... just snarky comments, of which I have a plethora )
-James
jamesohoh7 is offline   Reply With Quote
Old 01-20-2004, 08:48 PM   #5
Vortechcoupe
Member#: 33262
E36 M3
93 notch, X3
haha james i was thinking the same thing!! Oh and what Dan said about leaving the wheel on is correct. Go slow!!! New paint most likely won't chip or crack. Go slow and be careful!!! It also helps if you use a dremal to cut slits in the inner part so it can roll easier. I'm not sure on how much of lip there is on a WRX/STI, but if there is any, make some cuts. That way you can kinda do it in sections.
Justin C
Vortechcoupe is offline   Reply With Quote
Old 01-20-2004, 08:50 PM   #6
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
its about a half inch that goes slightly downwards. I probably dont need to roll it flat for clearance I just need it to go upwards or maybe even just at a right angle with the body.
Edit: well it seems to be going ok with a hair dryer and a louisvill slugger Though I cant just stick the bat in there and roll it back and forth that wouldnt do anything. But using the head of the bat on the fender and the tire as a fulcrum(Im pretty sure thats what its called been a while since whatever class taught me that) I can pry up about a quarter inch at a time, just doing that slowly has been working.
So far no paint damage other then what was already done by the rubber strips getting eaten. FYI those rubber strips are full of metal.
Old 01-21-2004, 03:49 AM   #7
Blugin
Member#: 5270
2008 EvoX MR
Red
After you're done, you can come over and help me knock on doors...
Blugin is offline   Reply With Quote
Old 01-21-2004, 10:00 AM   #8
strider98
Member#: 34815
you can't take the
sky from me
Dan...hahahahahahah
strider98 is offline   Reply With Quote
Old 01-21-2004, 10:04 AM   #9
DanzBorin
Member#: 7131
2015 Outback - Croc
to clear things up...
name is not:
Dan
or
Ron
tis Rob...
btw, for the first year or so, MissDanz's grandmother called me Rod...
Old 12-02-2004, 03:03 PM   #10
Treefallen
Member#: 42319
2004 WRX STI
I realize this thread is old, so maybe someone in the Austin area has the special fender rolling tool? If not, then the technique for fender rolling is simply to 'pry' the lip up every 1/4 inch using a piece of wood - right Alex? Do you achieve a pretty smooth result that way?
Treefallen is offline   Reply With Quote
Old 12-02-2004, 03:09 PM   #11
DanzBorin
Member#: 7131
2015 Outback - Croc
no, you actually roll a bat in the fenderwell... read my post... then read Vortechcoupe's...
Old 12-02-2004, 03:19 PM   #12
salaki
Member#: 10572
92X N62B44, ST 1050
CGK, LAX, & DFW
I've got a fender roller.
PM me.
salaki is offline   Reply With Quote
Old 12-02-2004, 03:23 PM   #13
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
PM me.
does it have louisville slugger written on it?
Old 12-02-2004, 03:26 PM   #14
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
PM me.
PM'd ya.
forced4 is offline   Reply With Quote
Old 12-02-2004, 03:30 PM   #15
Treefallen
Member#: 42319
2004 WRX STI
Of course I read it, and vortechcoupe's also. afpdl's just made more sens as far as faisability, I concur with afpdl it sounds mighty tough to stick a bat in there and just roll it. What I can imagine is to have someone move the car backward/forward with the bat jammed in there... I can only fit a finger between the tire (225/17/45) and fender btw.
Old 12-02-2004, 03:40 PM   #16
DanzBorin
Member#: 7131
2015 Outback - Croc
you must be lowered... try using a jack to put it on jackstands... and heat helps soften it up...
Old 12-02-2004, 04:27 PM   #17
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Thats what jacks are for, my rear tires currently have -1 finger gap. I did mine with the stock wheels and tires on the car, just used the tire as a pivot point and pryed, there is no actuall "rolling" involved. Its not completely smooth on the inside but that was never a concern of mine as its the inside of the fender. It may be worth it to drive down for forced4's deal, I may use it to get a little more clearance.
Old 12-02-2004, 10:27 PM   #18
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
I have seen, in my experience, that it is best to let a bodyshop do it. It is VERY easy to crack the paint.
if the bodyshop cracks your paint they repaint it for free
OneArmedScissor is offline   Reply With Quote
Old 12-03-2004, 07:45 AM   #19
txjunglist
Member#: 11926
2011 Outback Limited
Dark Grey
Default dings , your car ?
what happened?
txjunglist is offline   Reply With Quote
Old 12-03-2004, 11:46 AM   #20
Treefallen
Member#: 42319
2004 WRX STI
Salaki is planning a trip to Austin sometime soon I hear. Speaking of paint... are you sure it's paint they put on our cars?
Looks like I need to go Recaro seat shopping... QwikEVO Alaskan Impreza Club Forum -- AKIC 39 11-17-2009 01:18 AM
So, looks like I'm going to get ****ed hard dr_wheel Off-Topic 58 09-16-2005 08:08 PM
Looks like I need to get to the track... Big_Hitter Texas Impreza Club Forum -- TXIC 8 05-21-2002 12:43 PM
Need to get out of uhaul now! BlueScooby New England Impreza Club Forum -- NESIC 0 05-17-2001 05:36 PM
Who thinks 8Complex needs to get out more? ian/555 General Forum Archive 34 10-10-2000 04:12 PM
