Old 01-20-2004, 06:58 PM   #1
kAn9ArOo
Member#: 2294
Angry rear wheel bearings! screw them
i just got my rear wheel bearings replaced. again! for the 4th time. i have a 00 rs. what is going on?!
i know there was some discussion on this, before but have any of you had the same problem? contacted subaru? what about a recall?!@!??!?!? i am never buying subaru again.
kAn9ArOo is offline   Reply With Quote
Old 01-20-2004, 08:34 PM   #2
Karl
Member#: 13110
Which model?
What wheels are you running on your car?
Karl is offline   Reply With Quote
Old 01-20-2004, 09:33 PM   #3
Gonz
Member#: 18642
2005 Impreza WRX STi
It means that during the first replacement the hub or carrier where the new bearing presses into was damaged and slightly deformed. therefore every new bearing burns up quickly.
Do a search on this, the detailed info should turn up.
Gonz.
Gonz is offline   Reply With Quote
Old 01-20-2004, 11:47 PM   #4
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
I have the TSB on our Scoobymods site, check www.endwrench.com too and you will get some good info there too. As stated once they screw up the first install you'll just eat bearings left and right till they replace the carrier I think.
Peaty is offline   Reply With Quote
Rear Wheel Bearing vs. Rear Diff Noise? turbobird14 Transmission (AT/MT) & Driveline 7 03-11-2008 10:44 PM
('93-'01) Rear Wheel Bearing Mrepsher Impreza Forum 14 07-04-2001 11:58 AM
Changing the rear wheel bearing RyanC Brakes, Steering & Suspension 1 07-04-2001 10:52 AM
Rear Wheel Bearing Failure Piquet North West Impreza Club Forum -- NWIC 5 02-23-2001 02:04 PM
Rear Wheel Bearing...again Bob OM,Md Normally Aspirated Powertrain 10 12-26-2000 04:38 PM
