Old 01-20-2004, 08:01 PM   #1
Max Umbarger
Member#: 1112
2006 FXT
RBP
Default slow coolant leak thru timing belt cover
I have a slow coolant leak thru timing belt cover only when eng is running. I'm thinking water pump seal, but it is draing between center cover and pass side cover. HMM
any info is splendid!
Max
Max Umbarger is offline   Reply With Quote
Old 01-20-2004, 09:48 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
why not pull the timing belt side covers off so you can get a better look.
Jay
Oil leak from timing belt cover g-rider Service & Maintenance 5 07-01-2008 08:25 PM
leak from timing belt cover area grizz3000 Service & Maintenance 17 12-27-2006 09:53 AM
Oil Leak from timing belt cover abosworth Normally Aspirated Powertrain 26 09-15-2005 08:29 PM
dried coolant on top of timing belt cover supermoose Service & Maintenance 8 11-18-2003 11:02 PM
leak around timing belt cover horizontalz Service & Maintenance 2 07-09-2003 07:12 PM
