Old 01-20-2004, 08:14 PM   #1
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
Default Powersteering Flush / Replace with Synthetic
Anyone know how to do this? I think it's time to replace my powersteering ATF with some synthetic since everything else is synthetic
Jon
02 WRX 4EAT
iNfEk is offline   Reply With Quote
Old 01-21-2004, 01:16 PM   #2
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
suck old fluid with a turkey bayster and refill with synthetic
tekfoc is offline   Reply With Quote
Old 01-21-2004, 01:49 PM   #3
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
there isn't a place to train on the rack or any hard oil line? Kinda wierd since if I use the turkey baster I will only get the fluid in the resivore...
Jon
Old 01-22-2004, 05:30 PM   #4
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
How often should I change my PSF? It is not specified in the owner's menu. I think the menu calls for DOT3 brake fluid. Is synthetic better or is any plain old brake fluid fine?
Gunner is offline   Reply With Quote
Old 01-22-2004, 05:50 PM   #5
fredj
Member#: 13735
2002 Outback Sport
Sedona Red
What ever you do DO NOT use brake fluid!! It most likley calls for Dexron 3 ATF just as the 2002 Impreza manual does. Synthetic Dexton 3 should be OK.
fredj is offline   Reply With Quote
Old 01-22-2004, 07:16 PM   #6
Gunner
Member#: 36540
04 GGA
fredj, yes, you are correct. I need to check what I was smoking =D So how about the schedule? 60k miles?
Old 01-22-2004, 08:17 PM   #7
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
exactly what the other guy said... it does NOT call for brake fluid.. it calls for D3 ATF... however if you are going to fill your brakes up then you need Dot 3 brake fluid...
Jon
Old 01-22-2004, 11:03 PM   #8
esteve
Member#: 28716
2006 STI
You could disconnect the return hose at the PS reservoir and point it down into a drain pan while the car runs (have an assistant handy to turn the car on and off), making sure you keep the fluid level up. You would have to plug up the fitting on the reservoir you took the hose off of or the fluid will spill out. Just rig up a plug with a short length of hose with a hose pincher tightened down on the end.
esteve is offline   Reply With Quote
Old 01-23-2004, 11:00 AM   #9
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Exclamation use OEM fluid
Just change it in the resevoir a couple of times. Use Subaru OEM fluid. Don't use "synthetic."
vvk is offline   Reply With Quote
Old 01-23-2004, 12:21 PM   #10
DamnYank!
Member#: 38293
1995 M3
Avus Blue
why not use syn?
i've had excellent results with the Valvoline syn PS fluid.
taking a hose off to empty the whole sys gets messy. do the turkey baster, just do it about 3 times (driving in between of course). that will get it changed over almost completely...
DamnYank! is offline   Reply With Quote
Old 01-23-2004, 01:45 PM   #11
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Originally posted by DamnYank!
why not use syn?
sorry to sound like a n00b but can you make a step by step thing on this... I don't want to **** it up! since it's self bleeding I shouldn't have problems with air in the lines but how do I know that I have the new fluid in there vs the old one? I DO NOT want to mix synthetic and the other stuff... it totally defeats the purpose of trying to change the type of oil that is in there
Jon
Old 01-23-2004, 02:37 PM   #12
DamnYank!
Member#: 38293
1995 M3
Avus Blue
ok, this is how i've done it on several cars with no issues....
-buy a large bottle of Valvoline PS syn fluid
1. turkey baster (or whatever you like) and remove ALL fluid from the resevoir. refill to correct level with new fluid.
2. run the steering from lock to lock (wheel all the way left then all the way right) 5 or so times.
repeat steps 1 and 2 about three times.
now will EVERY SINGLE DROP OF OLD FLUID be out of there? no. will almost all of it be gone and replaced with the new fluid? yes.
this way you don't have to disconnect any hoses and you don't risk running the rack or pump dry (both bad things).
Old 01-23-2004, 03:07 PM   #13
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
ok.. well I'll be using Redline D4 Fluid.. the same stuff I have in my tranny right now.
how many quarts will I need to do this?
Old 01-24-2004, 04:53 AM   #14
Ozymandias
Member#: 44238
1996 Impreza w/2.2t
Yellow
do what i did when i replaced mine, replace your rack and pinion unit too!
if you do use the method listed by damnyank i personally wouldn't do it while the engine is running because your powersteering pump will also be running and if i recall the manual says not to run that dry.
Ozymandias is offline   Reply With Quote
Old 01-24-2004, 05:31 AM   #15
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
why'd you replace your RNP?
Old 01-24-2004, 12:58 PM   #16
Ozymandias
Member#: 44238
1996 Impreza w/2.2t
Yellow
my rnp had a serious leak and very badly needed repaired or replaced. i ended up gettting a rebuilt one. it was a really easy fix.
Old 01-25-2004, 02:20 AM   #17
cvalle-sd
Member#: 420
2001 Cr-V
Mobil 1 ATF - 'swat I did.
cvalle-sd is offline   Reply With Quote
Aggressive Flush fitments with Buddy Club and XXR Wheels with Tires! LOW PRICES! Apollo Performance SCIC Vendor Classifieds 79 10-29-2010 10:19 AM
Can coolant flush/replacement and brake bleed be done on rhino ramps? Asinine Service & Maintenance 15 02-21-2006 12:49 PM
Subaru of Schaumburg replaced my synthetic oil with dino juice Spool_up Mid West Subaru Owners Club Forum -- MWSOC 31 05-19-2004 09:44 AM
How often do you change engine oil with synthetic oil? malelee21 Service & Maintenance 53 04-14-2002 10:33 AM
Clutch fluid flush/replacement? GQ Transmission (AT/MT) & Driveline 0 03-31-2002 04:18 PM
