Old 01-21-2004, 07:24 AM   #1
Wacky
Member#: 24908
2003 Impreza WRX
Platnium Silver
Question 215/45/17 or 225/45/17
I am picking up a set of 17in Rota Tarmac II's for my 2003 WRX Sedan and have seen both 215/45/17 and 225/45/17 as viable options for tire size. Any advantage between those two sizes? I currently haven't lowered my car at all, but I plan on doing so this spring with either the Prodrives or the Eibach's so the drop will not be excessive. I am leaning towards the Pirelli PZero Nero M&S if that helps as well. Thanks.
Scott
Wacky is offline   Reply With Quote
Old 01-21-2004, 01:27 PM   #2
aberg
Member#: 20184
2002 Impreza WRX
bump
aberg is offline   Reply With Quote
Old 01-21-2004, 01:47 PM   #3
gellar
Member#: 31047
11 135i
Sedona Red
I'd go with 225... they look better and you'll have a more contact with the ground. I can't really see any reason not to go with 225s.
Sergi
gellar is offline   Reply With Quote
Old 01-21-2004, 02:34 PM   #4
gordon
Member#: 27665
'02 WRX wagon
WR blue
in addition to more rubber on the road, the 225 also has more sidewall, so it'll be a little less likely to be damaged by potholes and such.
-g
gordon is offline   Reply With Quote
Old 01-21-2004, 03:29 PM   #5
Wacky
Member#: 24908
2003 Impreza WRX
Platnium Silver
what about rolling diameter and overall weight? anyone a proponent of the 215?
Scott
Old 01-21-2004, 03:33 PM   #6
Wraith
Member#: 30364
2005 Devilish STI
Angelic white
Go 225. It will protect your rim more from any curbs, etc. Plus it looks better. Nothing looks worse than a tire that looks skinnier than the rim
Wraith is offline   Reply With Quote
Old 01-21-2004, 04:19 PM   #7
gordon
Member#: 27665
'02 WRX wagon
WR blue
rolling diameter of 225 is closer to OEM 205/55 r16.
http://www.miata.net/garage/tirecalc.html
Old 01-21-2004, 06:49 PM   #8
YinUCSD
Member#: 44945
06 LGT wag
yes this is true. do the math, 225-45-17 comes out to be almost exactly the same diameter of stock 205-55-16, so your speedo and gearing wont change. of course the section width of every 225-45 tire is different due to varying manuf specs. i can tell you that bridgestone re-070's that come on the sti are pretty much the same diameter as our re-92. im assuming because theyre both bridgestones, so all their ratios for their different tires will remain consistent.
if you plan on getting AS tires, get 225, the added dry grip is nice especially when you have AS tires and are compromising dry grip for cold grip.
YinUCSD is offline   Reply With Quote
Old 01-22-2004, 04:59 AM   #9
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
225/45/17 is pretty much what i've heard (and recommend) for people to use on their 17 x 7.5 rotas....
however i'd like to hear from someone who have put on 215 on a their rex sedan...
good luck either way.
SD
suby_dude is offline   Reply With Quote
Old 01-22-2004, 07:58 AM   #10
Orson
Member#: 25254
2003 WRX wagon
Increased tire width does not put a larger contact patch on the ground. The contact patch size is largely a function of tire pressure. What a wider tire will give you is a contact patch that is shaped more like a thin horizontal rectangle than a square.
Orson is offline   Reply With Quote
Old 01-22-2004, 03:03 PM   #11
HongKongBeef
Member#: 1574
2016 WRX
Red
I put 225/45/17 Pirelli Pzero Nero m/s's on last week. I had 215/45/17 Sumitomo htrzII's before. i feel the Pirelli's handle a lot better than both the sumitomo's and stock tires. The car turns in MUCH quicker now. i was surprised at the difference. I am lowered on Cusco Zero2's and dont have any noticable rubbing
HongKongBeef is offline   Reply With Quote
Old 01-29-2004, 02:27 AM   #12
kosoku
Member#: 51373
2008 Nissan Titan
04 SV650, WSMC #606
HongKong, what size wheels? 17X? and the offset?
kosoku is offline   Reply With Quote
Old 01-29-2004, 09:46 AM   #13
balajc
Member#: 15393
MY00 2.5RS Coupe 5MT
Silverthorn Metallic
go with 225!
you non-GC8 guys are lucky...225/45/17 on a stock GC RS would probably rub!!!
balajc is offline   Reply With Quote
Old 01-29-2004, 11:08 AM   #14
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
You should really only run 215 if you have a 7 inch wide wheel, even then you can still run 225 if you want. The only advantage to the 215 is it will effectively give you better gearing, which means quicker accelleration. But on the Rota wheels, which are all 7.5" wide, you should run 225/45/17. If you want to get even wider you could go 235/40/17, but depending on the tire and how much you lower the car you could have rubbing issues. But I've seen lots of people on here run that size with no problems, even a few with wagons.
Khail
khail19 is offline   Reply With Quote
Old 01-29-2004, 02:38 PM   #15
HongKongBeef
Member#: 1574
2016 WRX
Red
kosoku: rota SDR's. 7.5 width
WTB in NH: 4 take-off or near-new 215/45/17 or 225/45/17 all season tires ksnh NESIC Private Classifieds 0 04-18-2009 09:47 PM
WTB in NH: (4) Take-off or near-new 215/45/17 or 225/45/17 all season tires ksnh Private 'Wanted' Classifieds 0 04-18-2009 08:52 PM
215-45-17 or 225-45 17 tire size showcasewrx Brakes, Steering & Suspension 6 01-29-2003 03:35 PM
225/40/17s or 215/45/17 or 225/45/17s SGOSWRX Brakes, Steering & Suspension 18 11-13-2002 09:03 PM
215/45/17 or 225/45/17?? decolory Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-20-2002 01:00 PM
