Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 01-21-2004, 07:43 AM   #1
wrxracer55
Member#: 39435
2002 Impreza WRX
Sedona Red
Default to those that have installed silicone turbo inlet hoses...
did your turbo noise increase? after installing my perrin inlet hose/samco maf hose, i can really hear the turbo now. it sounds awesome, but i want to make sure it is supposed to be this way. i double checked, and every clamp is tight, and i am not getting any mils or having any idle/backfire issues from running too rich. i'm guessing its allright, but want to be sure. if this is how its supposed to be, then i think everyone should do this
wrxracer55 is offline   Reply With Quote
Old 01-21-2004, 08:55 AM   #2
BillT
Member#: 16169
2002 WRX Wagon
I currently have the Samco MAF hose and I'm thinking about doing the Perin inlet peice....how was the install? Did everything fit right? Would you do it again or recommend it? Thanks!
Bill
BillT is offline   Reply With Quote
Old 01-21-2004, 08:59 AM   #3
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
When I did mine (a year ago) I had a increase in turbo noise.
Need4Boost is offline   Reply With Quote
Old 01-21-2004, 09:00 AM   #4
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
I installed in the AVO inlet hose well over a year ago and have had no problems (other than the install PITA). I have noticed the turbo is a little louder (well suction air noise anyway) but it was more due to the short ram intake (the short ram intake really gives you the sucking air noise as I put the stock box back on in the winter).
Hope this helps
coyote73176 is offline   Reply With Quote
Old 01-21-2004, 09:17 AM   #5
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
I have the Perrin Inlet hose.
Install with a other-than-stock turbo might require removal of turbo. I have the 16g hybrid and i could not install the hose without removing the turbo. took like 5 hours. Had i known i was going to have to do that it would've taken only 2 or 3 but i tried to do it without taking the car apart with no luck.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 01-21-2004, 01:17 PM   #6
wrxracer55
Member#: 39435
2002 Impreza WRX
Sedona Red
install took a few hours, it is a tight fit. thanks for the replies. i do recommend this mod, i noticed faster spoolup and better throttle response.
Old 01-21-2004, 01:21 PM   #7
PureWRX
Member#: 11739
2002 Impreza WRX
Blue - VF-23, Vishnu
I have a similar setup: Perrin inlet hose, Perrin drop-in filter, and Zerosport maf hose. I have a VF-23 and it is very loud when the thing spools up. People who know nothing about cars will sit in my passenger seat and comment almost immediately "What is that noise? SOunds like a jet or something." So yes, this setup will make a normal audible turbo louder, which is something I personally like. I have also retained the factory BOV, and you can now actually hear the "Pshhhh" when it blows off.
As for installation of the Perrin inlet hose, took about 2 hours the first time. And a good part of that time was spent modfiying the intake box so the Zerosports pipe could fit in with the perrin inlet hose.
Rob
PureWRX is offline   Reply With Quote
Old 01-21-2004, 01:23 PM   #8
WR xplosive
Member#: 33031
2008 4B11T
P26 MZ314000
No Inlet yet, but will be installing Samco IC hose this weekend. Also, air suction is noticeable since I installed the Perrin SRI, and the TSX D/P. Spool is much quicker and engine's rumble is better after the PDE Flex U/P install last weekend.
WR xplosive is offline   Reply With Quote
Old 01-21-2004, 02:31 PM   #9
Kitt
Member#: 24621
2006 Legacy GT
2015 WRX STi
When I installed mine I noticed a definite increase in noise.
Kitt is offline   Reply With Quote
Old 01-21-2004, 02:56 PM   #10
S-1
Member#: 10842
07 2.5i Wagon
the only noise increase i heard after putting the perrin turbo inlet hose on was an annoying rattle at the beginning of 1st and 2nd gear...and that was from the new heatshield i also put on the same night and was hitting the wastegate actuator
that install was the biggest PITA btw
S-1 is offline   Reply With Quote
Old 01-21-2004, 04:53 PM   #11
BlueDemon
Member#: 10173
2005 WRX STi
I've got the BPM Turbo Inlet with the Zero Sports MAF pipe and I noticed a big difference in Turbo sound. Sounds awesome, but I also worried that something wasn't right.
BlueDemon is offline   Reply With Quote
Old 01-21-2004, 08:06 PM   #12
03WRXMA
Member#: 35081
2012 WRX
Which heatshield was this?
03WRXMA is offline   Reply With Quote
Perrin Silicon Turbo Inlet Hose instructions for MY04 WRX...HELP!!! cooljay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-07-2006 10:40 PM
FS NY: Red Perrin silicone turbo inlet hose garface Private 'For Sale' Classifieds 10 06-22-2006 05:11 PM
FS: new red perrin silicon turbo inlet hose. jbotage9er Private 'For Sale' Classifieds 9 09-14-2005 03:22 PM
NEW MRT Silicone Turbo Inlet Hose for 1997-1998 WRX hampster Private 'For Sale' Classifieds 5 05-17-2005 04:48 AM
WTB: Silicone turbo inlet hose Pedestrian Private 'Wanted' Classifieds 5 11-10-2004 08:16 PM
