Old 01-21-2004, 01:21 PM   #1
Zman
Member#: 26460
2003 WRX Wagon
Default tire pressure vs. size
For any given tire, is there a difference in recommended pressure for a 225 vs. a 215? (same rim, same profile)
Suby gives numbers for 215/45/17's, but (technically speaking) are those valid/equal for 225's?
Zman is offline   Reply With Quote
Old 01-21-2004, 01:53 PM   #2
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
yes they are valid because the recmmended pressure is based on the vehicle weight and that is not changing
Old 01-21-2004, 04:03 PM   #3
Zman
Member#: 26460
2003 WRX Wagon
Why then, is there a separate recommendation for a stock tire (32/29) vs. 215/45/17 at 33/32?
If there is a noted difference between a 205/55/16 and a 215/45/17, why wouldn't there be a difference between a 215 and 225? I'd guess that (again, technically speaking) that a 225 might actually be 'lower' than a 215, due to more width/support from the wider tire - but if any one knows, from a techinical standpoint, if that is true, I'd appreciate some more info.
Thanks, Zman
Old 01-21-2004, 04:27 PM   #4
rexxer
Member#: 27624
2005 WRX STi
World Rally Blue Pearl
Remember that the car manufacturer wants to be known for having a safe car... so, they want the car to be very neutral for the average driver. With a narrower tire, dropping the pressure will help give more grip. 32/29 with the stock tires gives more grip rearward... less ability to rotate the car... 'safer' for the average driver. As the width increases, the contact patch increases and the ability to rotate the car decreases... so the average driver will be 'safe' with a higher pressure (which will give better gas mileage than the lower pressure).
Safety vs. gas mileage.
rexxer is offline   Reply With Quote
Old 01-21-2004, 05:48 PM   #5
reks
Member#: 9567
2005 Legacy GT Wagon
I believe there are many threads which discuss the fact that the size of the contact patch does not change with tire width, only the shape of the patch.
Changing the tire pressure changes the contact patch size. So does the weight of the car as Luke stated above.
reks is offline   Reply With Quote
Old 01-22-2004, 05:56 PM   #6
Zman
Member#: 26460
2003 WRX Wagon
interesting..... I got an email back from Michelin, which said that since the 215's were recommended at 33/32, and the 225's were more volume, that the pressure would be lower, and they suggested 31/29 (which I think is too low) - but I did try setting down to 32/31, and the ride is smooooooth.... and the traction rocks...... response is down just a touch, but now I don't feel 'every' little bump in the road...... smooooooth.... and seems that the sidewalls hold up fairly well, no squirm.....waiting to see how much this will effect mpg.....
Tire pressure vs. durability oab97 Tire & Wheel 9 08-18-2005 07:22 PM
HD Front and Rear Sways Vs. Tire Pressure Sir_Xenon Brakes, Steering & Suspension 1 06-10-2004 12:30 PM
camber vs. tire pressure to stop rollover rsotak Brakes, Steering & Suspension 3 05-05-2004 09:53 PM
Tire wear vs pressure.. ? thrashvr6 Tire & Wheel 4 11-13-2003 11:23 AM
Kuhmos- tire pressure for WRX/stock size Tex-WReX2 Brakes, Steering & Suspension 3 01-09-2002 02:30 AM
Message Board Statistics All times are GMT -4. The time now is 03:27 AM.
