Welcome to the North American Subaru Impreza Owners Club Saturday November 21, 2009
Old 01-21-2004, 03:36 PM   #1
DANACoOp
Member#: 51468
04 Had a WRX
Had SRT4, now '07 Si
Default Need how to on boost gage install
I want to install one, but is it simple, or will it take all day? I've been reading about boost spikes with exhaust systems, so I figure I should get one before I do my exhaust.
DANACoOp is offline   Reply With Quote
Old 01-22-2004, 12:28 AM   #2
SubieStyle
Member#: 48936
I Do Installs On The
Side;) PM me for details!
The factory one is hooked up to the vacuum line that goes to the top of the BOV/ Recirc. Valve. They just put a little "T" fitting onto it & run the hose to the gauge. Pretty simple if you ask me! Hope this helps.
Will.
SubieStyle is offline   Reply With Quote
Old 01-23-2004, 02:03 AM   #3
cadprowrx
Member#: 43938
'03 WRX Sedan
white
Depends on how complicated you make everything. I'm a wiring nut, so I had to make a nice harness for my three gauges with 2-pin plugs, shrink wrap etc, and "had" to have the lighting dim with the dash lights. Also, when it came to boost, I also put in an adapter off the boost line for a Hobbs switch (for my IC sprayer), and I also ran everything in -3 AN, so it took awhile to route everything, plus I ordered everything in advance. For the "normal" installation, give yourself 2 hours or so.
cadprowrx is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 11:27 AM.
