Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 01-21-2004, 06:42 PM   #1
cronic
Member#: 9749
Titan/WRX
Unhappy 3.3 OHM resistor, but still have airbag light!
I ordered some 3.3ohm 1/4 watt resistors and plugged one in each yellow airbag connector and i am still getting an aribag light.. I have stock steering wheel so that is not an option..
Any help will be appreciated, Thanks
Dave
cronic is offline   Reply With Quote
Old 01-21-2004, 11:13 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO
I think they may have to be more than 1/4 watt. Take them out and check them visually and with an ohmeter to see if they are burned out.
Old 08-17-2004, 01:15 PM   #3
igoeasy
Member#: 5690
02 WRB GDA
Which of the two values would work best for this ?
3.0 OHM ½W or
3.6 OHM ½W ?
I'm ordering this from partsexpress and 3.3ohm is not available.
Seems like some are not having luck with 3.3ohm ¼ watts.
The subaru resistor made by Kentmore is a 3 ohm 1 watt resistor. Which one will it be ?
igoeasy is offline   Reply With Quote
Old 08-17-2004, 02:12 PM   #4
cnk
Member#: 10757
2002 WRX Sedan
Platinum Silver Metallic
I'm using 3.0 OHM 1W resistors from partsexpress and no problems. I would say that 1/4W is definitely too low.
Calvin
cnk is offline   Reply With Quote
Old 08-17-2004, 02:17 PM   #5
cnk
Member#: 10757
2002 WRX Sedan
Old 08-18-2004, 12:15 AM   #6
igoeasy
Member#: 5690
02 WRB GDA
Just ordered them. Thanks Calvin for the reassurance of getting the right part !
Old 08-18-2004, 12:47 AM   #7
cnk
Member#: 10757
2002 WRX Sedan
No problem. Good luck.
Calvin
Old 08-28-2004, 01:26 PM   #8
readymix
Member#: 59839
2004 WRX
Platinum Silver
is this ohms or KOhms. 3.3ohms isn't that much and can be made by just winding up some cable.
readymix is offline   Reply With Quote
Old 08-28-2004, 01:31 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO
3.3 OHMS, not K. You'd have to wind up a lot of cable to get that much resistance.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 12:55 PM.
