Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 01-07-2004, 07:22 PM   #1
Mike Rockefeller
Member#: 52154
1998 Outback Wagon
Default H4 vs H6 ,Head Gaskets
My '98 Outback runs great in between each major repair. However I have a list of major repairs that would make any Scooby fan turn Green as a Ghost. The latest problem is of course the head gaskets at 96,000 miles. The car runs fine for 30 to 60 miles then suddenly the temp gauge goes from middle to off scale and the antifreeze overfills the bottle. Dealer drove the car and confirmed my thought although did not test the compression nor knows which head is leaking, and estimated $1100 repair. I opted for a $650 repair from an independent garage who specializes in Subaru. Dealer also says he does not machine the heads. Independent says he always does.
> Dealer still charged $90 for the 1.5 hour test drive.
> Any comments on 1) the replacement of both gaskets just because and 2) Machining necessity ?
> 3) Since this is a more common problem with the DOHC Phase 1 engine and not as common with the simpler SOHC, does anyone know if the H6 engine which looks like the old DOHC design with two more cylinders tacked on, would be any better ?
> "Ready for a change"
Mike Rockefeller is offline   Reply With Quote
Old 01-15-2004, 06:44 AM   #2
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
Rally Medic is offline   Reply With Quote
Old 01-21-2004, 11:52 PM   #3
BLUJI
Member#: 52518
2002 OBS
savannah
Have a Nice Day?
Pressure test radiator cap, air trapped? try running with cap only 1/2. same problem it is collant path obstruction, RegardsNLuck
BLUJI is offline   Reply With Quote
H4 vs. H6 rev limit question. sick1.8t Built Motor Discussion 14 03-19-2010 12:26 AM
H4 to H6 Swap Subarudave09 Subaru Conversions 8 06-23-2009 11:40 PM
Looking to buy a 00-02 OB. H4 or H6 Engine? compression Outback Forum 1 09-14-2006 11:09 PM
Old head gaskets vs new 4 layer ones White2.5GT Normally Aspirated Powertrain 10 03-25-2004 06:54 AM
Head gasket diff in early EJ20 vs EJ22 Speedwagon Legacy Forum 1 05-30-2003 09:11 AM
