#1 |
Member#: 25448
Vehicle:had to many cars 08Corolla 00Si |
My right hid light is not working, i check the bulb, its good
I think that the ballast and ignitor are bad, I got the kit for no more than 2 months.... I bought it from another nasioc member and the kit was new... anyone knows where can i get the ballast, maybe someone has that for sale??? I will post also in wanted section PLEASE HELP Peter p.s the kit is H1 |
#2 |
Member#: 8023
Vehicle:2004 2.5 RS |
Could you say a little more about how you have them wired. Are the grounds for the ballast wired directly to the battery ground or too chassis? Not to car harness ground?
#3 |
Member#: 25448
I connect the grounds to the connections from the harness, they both was workin perfectly... I took the bulb and connect it into the workin headlight and the bulb is ok, i took the ballast out, and put it straight to the battery and nothing, when i took the workin one and put it straight to the battery it was workin
There is power comin into the ballast but nuttin coming out... Peter |
#4 |
Member#: 25448
anyone got problem like that?
peter |
#5 |
Member#: 52185
VIC
Vehicle:09 Sti DGM |
same thing happened to me..did u disable your daytime running lights? if u didn't thats why your ballast is not working...hid's have to run on full power not the power of daytime running lights...u have to get that ballast fixed or replaced
#6 |
Member#: 25448
yes I disable daytime running lights..... it was working for a month
I order new ballast, i just hope that this one will work for a longer time Peter |
