Old 01-21-2004, 10:41 PM   #1
Wh1t3WRX
Member#: 52412
Default What oil to use/other maintence?
Hello, I was just wondering what oil eveyone uses in their wrx and what is recamended. I know that the previous owner did reguar oil changes of 10-w30 non-synthetic, and i was just cerious if i should switch over to synthetic, the car has just over 40,000 miles now. Also at this millege what alse would u recamend getting done? Plugs, wires, tranny/diff fluid, anything? Thanks.
Wh1t3WRX is offline   Reply With Quote
Old 01-22-2004, 12:45 AM   #2
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Keep using a brand name 10W-30 non-synthetic.
vvk is offline   Reply With Quote
Old 01-22-2004, 02:08 AM   #3
HomerJay
Member#: 1135
2005 WRX WAGON
You might think about switching to 5w-30 for the winter. It's slightly thinner and will better during those cold Michigan winters. I'd suggest plugs soon as well as changing out your tranny and rear diff if not done yet by previous owner.
HomerJay is offline   Reply With Quote
Old 01-22-2004, 11:45 AM   #4
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
I use Mobile 1 5w-30 synthetic oil. Change it about every 6000 miles now, and switched over from regular oil at 3000 miles. At 40K, if it has not been done already with the 30K service you should have the fuel filter changed, air filter, brake fluid changed, and coolant fluid changed out. Plugs do not need to be changed until 60K, anything else is up to you.
K
rankink is offline   Reply With Quote
Old 01-22-2004, 09:25 PM   #5
Wh1t3WRX
Member#: 52412
Cool guys, thanks. We just stated carrying Royal Purple at work so i might start running that, any imput? I can get it for dirt cheep. Any more imput on if i should run synthetic or not? Ive herd turbos love synthetic but engines dont so much.
Old 01-25-2004, 01:40 AM   #6
Raptor75104
Member#: 52363
2009 Legacy GT
Ruby Red Pearl
If you can get Royal Purple dirt cheap, do it. My past experience with a Saab 9000 Turbo with APC in Germany, frequently, on the autobahnen at 130 mph+ for extended periods. I'd recommend synthetics in a turbo car. It's not mandatory, but it is a good idea, if you drive hard, to run synthetics as they don't break down like dinos.
Raptor
Raptor75104 is offline   Reply With Quote
Old 01-27-2004, 11:49 PM   #7
cwiceman
Member#: 29006
This is rather odd, but I'm gonna inject some interesting fuel into the fire. I work for Valvoline, and although I know that in general it is better to use Synthetic in turbocharged vehicles because it has a tendency to break down and "coke" in the turbocharger, it recommends in our manuals and is even on one of our certification tests not to use full synthetic or synthetic blend is any Subaru. I'm not sure what would be the reason for this, if any, but I thought I'd just let ya'll know...
cwiceman
cwiceman is offline   Reply With Quote
Old 01-30-2004, 12:25 AM   #8
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
hmmm ... it would be very interesting to know why. IIRC the WRX manual says that synthetic is OK but to keep the same change intervals.
Also, the WRX should run 5W30 year-round except maybe in very hot conditions. I like Castrol GTX dino.
Mike Wevrick is offline   Reply With Quote
Old 02-11-2004, 01:28 PM   #9
zsurfrin
Member#: 11034
Platinum Silver
I run that mobil 1 15w-50. Should i be using a 5w or 10w? I just figured living in Florida 15w would be my best becuase of the heat. What would be the advantages or disadvantages to running a lower weight oil?
zsurfrin is offline   Reply With Quote
Old 02-11-2004, 01:58 PM   #10
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
15w50 is probably not a good idea... the manual is pretty clear about what weight oils to use for varying temperatures.
If I lived in FL, I'd be running 10w30 year round.
As for synthetic, I don't particularly care what Valvoline says... my SUBARU owner's manual says synthetic is fine after the break in period.
heffergm is offline   Reply With Quote
Old 02-13-2004, 02:16 PM   #11
Mike Wevrick
Member#: 24654
1957 Taggart Comet
15W50 is too thick; you will not get proper lubrication when you first start the car up. 10W40 is as thick as I would go even in Florida. The outside temperature is not that critical since your engine gets way hotter than that. Its upper temp is determined by the cooling system and will be pretty much the same no matter what the air temp is.
need to flush 04 6mt what oil to use? gto7419 Transmission (AT/MT) & Driveline 5 03-03-2009 05:58 PM
Cooking ?? What oil to use to make hardshell tacos? crowbar Off-Topic 17 10-25-2004 10:42 PM
What oil to use in tranny and diff (Redline)? WRBLUEWAGON Transmission (AT/MT) & Driveline 1 06-20-2002 11:58 AM
what oil to use PHIERCE Normally Aspirated Powertrain 4 08-17-2001 06:49 PM
