Old 02-25-2004, 05:13 PM   #1
granteeton
Member#: 53529
Default fuel pump controller
for those of you who have done the gc8-gda swap, did you just hardwire the fuel pump controller into the ecu/harness? i think this is how i'm going to do it, just wanted to know if there was something else that i needed to do.
-keaton
granteeton is offline   Reply With Quote
Old 02-25-2004, 06:31 PM   #2
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
blue ridge pearl-sold
Yep just hard wire it, I have a pic for you at...http://www.rs25.com/forums/showthrea...5&pagenumber=3
imprezaclipse is offline   Reply With Quote
Old 02-25-2004, 06:51 PM   #3
granteeton
Member#: 53529
cool. that's the same swap i'm doin right now, 00 rs to 02 wrx, also brp.
Old 02-25-2004, 06:53 PM   #4
granteeton
Member#: 53529
did you wire up your dlc when you did the swap?
Old 02-25-2004, 07:01 PM   #5
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
Whats dlc?
Old 02-25-2004, 07:02 PM   #6
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
Good luck, I'll be here all the way if you need me.
Old 02-25-2004, 07:09 PM   #7
granteeton
Member#: 53529
Originally posted by imprezaclipse
Whats dlc?
data link connector. the black obd-2 port under the dash.
Old 02-25-2004, 07:15 PM   #8
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
Oh had you just said OBDII connector I would have known , anyways I did not touch any of that under the driver side, I did however splice the associated wires from my old RS harness to the wrx ECU so it would still work.
Old 02-25-2004, 07:43 PM   #9
granteeton
Member#: 53529
splice wires from the connector to the ecu so the connector would work? which ones did you splice? i'm working on figuring that out right now and it's takin a little while.
Old 02-25-2004, 09:38 PM   #10
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
You have your ecu I/O signal list for both your RS and WRX right? They are all listed there. Just simply match them up, ex. the RS has a red/white wire which goes to the line end check connector and so does your wrx ecu harness,splice them together.
Old 02-25-2004, 10:51 PM   #11
KevinHeist
Member#: 50667
2000 Impreza Coupe
Enginuity Tuned
get it right man! 03 WRX.
Everyone, this is the guy who's wiring my car, so please give him good advice
I have an 03 engine, 03 ECU, and through the strange grace of God, an 02 harness.
KevinHeist is offline   Reply With Quote
Old 02-27-2004, 10:49 AM   #12
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I don't know about hardwired. My fuel pump controller is connected using the same factory connectors it came with. I just tucked it under the passenger side kick panel.
-Jon
stimpy is offline   Reply With Quote
Old 02-27-2004, 11:48 AM   #13
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you could always see if any link guys are selling theres...because some of them have fuel cutting out because of it....talk with them...but I'm keeping mine...sorry
USDM STI Fuel Pump Controller vs USDM WRX Fuel Pump Controller Boeleni Subaru Conversions 8 11-06-2009 10:33 AM
05 WRX Fuel Pump Controller, New 650 Injectors, STI Fuel Pump,TXS Catch Cans mrtrex Engine/Power/Exhaust 16 06-09-2008 06:55 AM
Running an External pump off the stock fuel pump controller? jigga Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 08-07-2007 04:59 AM
NEED ASAP!: 04/05 STI Fuel Pump Control Unit aka Fuel Pump Controller. dan2304k Private 'Wanted' Classifieds 0 05-25-2006 07:25 PM
no fuel pump controller = wear out pump? 2slofouru Subaru Conversions 9 09-15-2005 03:51 PM
