Old 01-22-2004, 12:09 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Question P0420 Catalyst System Efficiency code help?
I am getting this code P0420 Catalyst System Efficiency Below Threshold (Bank 1) so I replaced the front O2 sensor only to get the same code thrown. I have had my kit for years never before coming across this problem. I have larger injectors and I am wondering if possibly it's to much fuel? But then wouldn't I get some sort of fuel trim code? Help?
Joshua
yebokmj is offline   Reply With Quote
Old 01-22-2004, 12:23 PM   #2
leondal
Member#: 43114
1998 Legacy GT Turbo
Green
Maybe the cats need to be replaced.....
leondal is offline   Reply With Quote
Old 01-22-2004, 12:35 PM   #3
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Actually the front O2 sensor doesn't have much to do with this (at least I don't think). The rear O2 sensor is the one that will throw this code. Its probably the cat going bad or the rear O2 sensor dying.
lotusTT is offline   Reply With Quote
Old 01-22-2004, 12:46 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
the cat is dead
Old 01-22-2004, 12:52 PM   #5
yebokmj
Member#: 2213
Brilliant Red
Default Bank 1?
Bank 1 though is before any of the cats why would the cats be effecting anything?
Joshua
Old 01-22-2004, 01:05 PM   #6
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Well this is the same CEL you get from running cat-less, I'm not sure what the Bank 1 part means though.
Old 01-22-2004, 01:15 PM   #7
yebokmj
Member#: 2213
Brilliant Red
Default Bank 1
I have two high flow cats. Bank one is the first O2 sensor. Bank 2 is the second O2 senor after the cats.
Joshua
Old 01-22-2004, 01:21 PM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
actually it's B1S1 and B1S2 which is B1S1=Primary B1s2=Secondary
P0420 is a bad cat, not a bad O2 sensor
Old 01-22-2004, 01:45 PM   #9
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
If you have a custom (with a downpipe which replaced the stock cat), you will eventually get the P0420 CEL code. It is completely normal, does NOT mean your cat is going bad, just do an ECU reset, if the light annoys you. Or go standalone,
Wedge is offline   Reply With Quote
Old 01-22-2004, 02:19 PM   #10
yebokmj
Member#: 2213
Brilliant Red
Default I have cats
I have the JC Sports GB Kit, so I have two 2.5 High flow cats in my down pipe. I can understand why a bad cat or lack of cat would give such a code for Bank 2 but why bank 1? It's readings are before the cat.
Joshua
Old 01-22-2004, 02:48 PM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
no, there is no B2 on these cars, only B1....B2 woudl refer to a V6 with 4 O2 sensors
Old 01-22-2004, 03:18 PM   #12
yebokmj
Member#: 2213
Brilliant Red
Default I see
Okay I understand now. So is there a way to help clean my cats? Or are they not clogged but gone broken down over time. I do get a lot of popping and such. I don't have the money to get a new down pipe. I can alway break them out but I would prefer not to. Any suggestions would be apprecited.
Joshua
Old 01-22-2004, 03:19 PM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
there's nothing you can do except replace them, how many miles are on them?
Old 01-22-2004, 03:22 PM   #14
yebokmj
Member#: 2213
Brilliant Red
Default Hmm
Between the two cars it's been on I would say 40-50 thousand? I'm poor at record keeping
Joshua
Old 01-22-2004, 03:25 PM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
well REvision had the cats in his JC Sports Kit fall apart as well, you coudl try contacting PDM turbos who made the kits and see if he will do anything for ya.
Jeremy
Old 01-22-2004, 08:40 PM   #16
Unsung Boxer
Member#: 37196
HndaTch hit it right on the head.
Bank 2 is only on V formation cars where they run 2 primary 02 sensors.
Sensor 1 is primary
Sensor 2 is secondary
Cat inefficency is only seen by sensor 2
Check to see if the cat is toast by jacking up the car and smacking the catalyst. If you hear stuff rattling around in there, its trashed. If you see bits of catalyst in the tailpipe or muffler, it is junk.
Alot of times, its the sensor itself. Check by replacing the secondary sensor with your old primary one... it should work
They are both 3 wire 02 sensors.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 01-23-2004, 02:00 AM   #17
Turbotegra
Member#: 1389
2007 IS350
05 VFR 800 ABS
hey yebokmj,
I have the same kit(bought it used)with the same problem as well but my secondary cat came hollow. You should be able to bring your downpipe to a local shop and have some new cats welded in instead of buying a whole new downpipe. I spoke to Joel Cox early last year about a new downpipe and he didn't seem very interested in making me another one.I think JC/PDM has gone through several redesigns on the pipes, whick makes it a hassle, but I could be wrong.
Rog
Turbotegra is offline   Reply With Quote
Old 02-02-2004, 01:34 PM   #18
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
I just got that checked out today since I got a CEL a week ago after putting a 2.5" catback exhaust...reset the ecu and went away momentarily and then it came back up.
P0420 code at autozone...is it time for turbo yet? LOL or will fuel injector cleaner work?
Kevin
latinskllz is offline   Reply With Quote
Old 02-02-2004, 05:33 PM   #19
jdchmiel
Member#: 926
i yhave heard that the borla headers will cause this too. It seems like basically anything that alters the temp of the exhaust before it gets to the cat can cause this. With the borla headers I read in a thread here that thermal wrap fixed the code. Maybe wrapping your exhaust up to the cat will get teh cats hot enough to be effective?
you mentioned larger injectors.. what are you controlling them with? I know running too rish all the time will destroy a cat, and leaded gas might kll the o2 sensors..
If you do get a new o2 sensor, can I have your old one? My car came missing a sensor so I need to weld a bung in and would like to just splice a universal sensor in with the old clip instead of buying a new subaru one.
jdchmiel is offline   Reply With Quote
Old 02-03-2004, 02:41 AM   #20
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
IIRC, the P0420 is caused by aftermarket goodies( like the Borlas I have) and the code can be pulled but it may return(as in my case). The "best" step is to get this: http://www.ponyexpressperformance.co...liminator.html
After I double check the recent CEL, I'll have that done.
joubtt is offline   Reply With Quote
Old 02-03-2004, 03:54 AM   #21
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
P0420 is not usually cuased by a header, then again if the header is not heat wrapped or jey hot coated i could see this being possible, if the car is fairly stock it needs a catalyst section which is covered under a 8yr/80k warranty, and that's federally mandated/
Jeremy
Old 02-03-2004, 11:39 AM   #22
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Jeremy
hmmm i put fuel injector cleaner, reset the ECU and we'll see how many miles until it CEL's again (if it does, crossing fingers)...
kevin
Old 02-18-2004, 12:00 AM   #23
electricpork
Member#: 9498
03 Bugeye
Junkyards are fun!
Thanks hndatch, Ive been looking everywhere for an explanation of bank 1, sensor 2.
I just installed a turboback with a scoobysport p0420 fix and now Im getting a P0138 instead (O2 sensor circuit high voltage, bank 1, sensor 2). What could be causing this?
Ben
electricpork is offline   Reply With Quote
Old 02-18-2004, 10:23 PM   #24
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
i still haven't gotten a CEL again...I would say try Lucas Fuel Injector cleaner with 93 Octane and reset the ecu...
Old 02-19-2004, 03:43 AM   #25
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Ben
you crossed a wire when you installed the MIL eliminator
Engine Misfire = Catalyst System Efficiency Below Threshold skifree09 Normally Aspirated Powertrain 9 02-25-2010 07:28 PM
P0420 Catalyst System Efficiency Below Threshold (bank 1) smoky Built Motor Discussion 4 11-13-2009 03:14 PM
P0420 Cat system efficiency BoXinWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-07-2009 12:42 AM
CEL - P0420 - catalyst system efficiency below threshold (bank1) Gilbert927 Newbies & FAQs 19 01-11-2008 07:42 PM
P0420 Catalyst System Efficiency Below Threshold Al Thorp Engine Management & Tuning 12 02-03-2007 10:56 PM
