Old 01-22-2004, 02:39 PM   #1
ScobyWRX
Member#: 49690
2006 WRX limited
Gray
Question EJ25t swap into WRX
has anyone done this ?? if so what TB did you use and how did it turn out
ScobyWRX is offline   Reply With Quote
Old 01-22-2004, 04:30 PM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
By ej25t do you mean a sti ej257 short block? If so yes, and there a a number of threads on it. Check out the FAQs around here and start you search here....
http://forums.nasioc.com/forums/show...ort+block+info
http://www.i-speed.us/news/sti_dyno_2.shtml
If you mean turboing a ej251 rs motor then look in Aftermarket Forced Induction....
Old 03-12-2004, 02:19 PM   #3
ScobyWRX
Member#: 49690
2006 WRX limited
Gray
yes EJ257
Old 03-12-2004, 04:36 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The other question that I'm sure totoherbs meant to ask was what ECU were you using with this?
-Jon
Old 03-13-2004, 07:04 PM   #5
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
8cmFP Red, RA 5spd, Hydra
Here is a little info. This is so you can your wrx ecu with out AVCS. If you want to use the AVCS you have to do alittle more work. This is also the JDM VER8 forester sti 2.5 engine, it is said to be the same a s the USDM EJ257
http://forums.nasioc.com/forums/show...hreadid=516466
CK02WRX is offline   Reply With Quote
Old 03-13-2004, 08:37 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
or just save your self a world of hurt and keep the ej205 heads .. and wrx ecu and swap in the ej255/7 short block
Old 03-13-2004, 08:40 PM   #7
totoherbs
Member#: 7321
.... 122 IggPoints
6 Speed swap Into Wrx ....Axle SWAP? the real suby dude Transmission (AT/MT) & Driveline 1 05-06-2009 04:43 PM
Jdm ej207 swap into wrx is finished. Its crazy. WRXerRacer Subaru Conversions 10 01-03-2005 08:17 PM
6sp Swap into WRX DCCD Question highboostinrex Transmission (AT/MT) & Driveline 1 12-22-2004 01:50 PM
STi short block swap into WRX pegdrgr Subaru Conversions 97 07-20-2004 08:43 AM
Legacy GT 5EAT Swapped into WRX? Shikamaru Transmission (AT/MT) & Driveline 0 06-04-2004 11:18 AM
