Old 01-22-2004, 09:35 PM   #1
WanganRunner
Member#: 48091
Default Reverse Synchro
Long Story Short: Just got my 2k4 rex, 980 miles on it, had it for 10 days, makes a knocking sound in reverse. I took it to the dealer and they told me the reverse synchro was broken. They ARE fixing it under warranty, but said that it's just a "One time act of goodwill". They said that in order to do this sort of damage, one would have to accidentally shift into reverse while going forward 25mph or faster.
The problem:
I KNOW I didn't misshift into reverse, I've never done it before, but I'm sure I'd know it if I did. I've been babying the hell out of the car given that it was still in the break-in period. Thus, what the hell else could cause the reverse synchro to break with only 980 miles on the car? Any theories appreciated.
My only ideas:
Maybe that sort of misshift isn't really noticable (bloody unlikely)
Factory defect (anyone else had this problem)
Case Flex screwed synchro up (Is this possible, and if so, what the hell causes case flex?)
Tranny Gremlins.
ANY input is greatly appreciated, I just got the car, I love it, but this is reeeeedikalus. (and yes, I know I posted the same thing over on I-club, I really wanna know what people think of this).
WanganRunner is offline   Reply With Quote
Old 01-22-2004, 10:09 PM   #2
yobtah
Member#: 48939
Reverse is a straight-cut non-synchronized gear. There is no reverse synchro.
Does it make the knocking sound only while you're moving in reverse or while you're stopped with the clutch pedal pressed and gear selector in reverse?
I don't think case flex would cause synchro problems, but I suppose case flex could cause the actual gears to mesh incorrectly. That could chip or break gear teeth. If the knocking happens while you're moving and matches speed in reverse, chipped gear teeth might be a possibility.
yobtah is offline   Reply With Quote
Old 01-23-2004, 07:29 AM   #3
WanganRunner
Member#: 48091
Didn't get a chance to check the "only when moving" thing. I got told this about the reverse synchro over on i-club too, which worries me, because the dealer definitely said it was the reverse synchro, which probably means they're lying. I need to find another dealer.
Old 01-23-2004, 01:08 PM   #4
Hamzor
Member#: 19541
Default Actually....
Reverse does have a syncro.
http://www.usdmsti.com/photos/SalesTraining/sti7.jpg
(bottom of page)
Hamzor is offline   Reply With Quote
Old 01-23-2004, 01:40 PM   #5
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Default Re: Actually....
(bottom of page)
That has got to be a typo. I've never heard of a syncro in a reverse gear on any transmission. Plus I thought the 5 speed had single syncros on first and second, not double cones as the graphic you linked to says.
It is, of course, entirely possible that the information I have read on this site is merely hear say...
Stanley is offline   Reply With Quote
Old 01-23-2004, 11:50 PM   #6
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
#(28), page "MT-9", in service manual #MSA5T0213A lists a "Synchro cone (Rev)"
It sits near the back end of the "Main shaft Assembly" the function apears to do with the intermesh of 5th gear to a "Coupling Sleve" that inturn ends up going to the actual reverse idler gear...
If that was worn... I don't know what the cause or effect would be...
I doesn't apear to be of the type that we are used to... it isn't directly "reverse" but one of a couple of things that need to mesh to make it happen...
Reverse has a synchro in it but the gear its self is NOT synchronized...
GLwagon is offline   Reply With Quote
Old 01-24-2004, 01:12 AM   #7
jandro62
Member#: 50921
2004 WRX
I also have a MY04. When just rolling back at say 1mph I tried to shift the car into Reverse and got one hell of a noise from the tranny. I'm gonna vote for reverse is not synchronised.
jandro62 is offline   Reply With Quote
Old 01-24-2004, 01:16 AM   #8
firedust
Member#: 38795
2003 WRX
Sonic Yellow
You have a WRX. The manual may say its synchroed ,but what the hell does the synchro do?
youve surely, just like me been parallel parking or doing a 3 pt turn and put it in reverse before the car was stopped and gotten a grind. i did it once, and once again by accident. never again...doesnt feel like it has any synchronizer.
firedust is offline   Reply With Quote
Old 01-24-2004, 10:22 AM   #9
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
Re-read the post by: gl-wagon.....
LyveWRX is offline   Reply With Quote
Old 01-26-2004, 10:34 AM   #10
Dougie01
Member#: 50216
2005 Honda Insight
1993 Miata, 1953 CJ-3B
There's definitely a synchro on the 04 STi reverse. It's not all that strong so you can over-ride it if you try, but it's there. And there are other transmissions with this also. The Miata has it, for example.
Dougie01 is offline   Reply With Quote
Old 01-26-2004, 12:26 PM   #11
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
Make sure that you do not sign anything that states that you accept the repair as a "one time courtesy". They are bloody ignorant by assuming that the reverse cannot be defective to start with. Maybe they are instructed by Subaru, who knows. But just make sure you do not end up at the short end of the stick.
Gunner is offline   Reply With Quote
Old 01-27-2004, 12:05 AM   #12
WanganRunner
Member#: 48091
Can I just refuse to sign it? They've already told me that's what they're calling it, a "one time act of goodwill". If I don't sign it, won't they refuse to pay for it under the warranty? I'm picking the car up either tommorow or wednesday, so quick response from ANYONE knowledgable on these "one time" things would be great.
Old 01-27-2004, 12:13 AM   #13
BAC5.2
Member#: 43996
The Aggressive (tm)
You don't know about it..
How do they know that isn't a manufacturer defect?
BAC5.2 is offline   Reply With Quote
Old 01-27-2004, 12:25 AM   #14
Gunner
Member#: 36540
04 GGA
I have no experience in this, maybe someone can give a better response, but here's mine.
Firstly, I don't think they will need you to sign on paper and accept that it is a "one time courtesy" and that Subaru will not be responsible for future repairs. If they tell you orally that it is a one time courtesy, tell them that you do not accept it and that in the first place you did not "shift into reverse at 25mph or more". Moreover, according to law, the manufacturer is responsible for defects as long as they have "proof" that user operation and modification resulted in the break-down. Ask them for proof that it is not workmanship issue. Moreover, what happnes if they failed to fix it correctly, if it is just "one-time" and they couldn't fix it with just one try (which often happens), then you are out in the cold.
If in case they really ask you to sign something on paper to accept it, I personally wouldn't sign it. I would leave the car there and find an attorney and write them a letter about the issue stating my rights.
I really don't know what to expect from the dealership, maybe some Subaru tech here can give some insights.
Old 01-27-2004, 07:14 AM   #15
WanganRunner
Member#: 48091
Has anyone here ever had to actually sign something?
Am I losing a synchro gear? Worse? (4EAT) Do I have synchro gears? kaisersouse Transmission (AT/MT) & Driveline 5 09-24-2009 08:05 AM
How do I make my AVN 5435 switch to the reverse cam when i select reverse gear? jigga Car Audio, Video & Security 7 07-09-2006 01:44 PM
Is 1st gear Synchro linked to 4th synchro in anyway?? WRexxer Transmission (AT/MT) & Driveline 1 08-21-2005 09:23 AM
Reverse Gear and Synchro strange noise ? ludecrous Transmission (AT/MT) & Driveline 6 09-03-2004 04:42 PM
Stalling in reverse and rough in reverse... Evaider Transmission (AT/MT) & Driveline 5 01-23-2002 07:32 PM
