Old 01-22-2004, 10:15 PM   #1
linux>windows
Member#: 49517
Default STi Motor into an OBS?
Is this practible? Would I end up killing myslf, and if I went standalone, how would I do boost, wipers, etc..?
linux>windows is offline   Reply With Quote
Old 01-22-2004, 10:29 PM   #2
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
obs impreza or legacy? i-speed did a swap in to an OBS I dont see what would be so different swaping an ej20 in a obs compared to a non OBS
scobaru is offline   Reply With Quote
Old 01-22-2004, 10:32 PM   #3
linux>windows
Member#: 49517
Impreza.. How much does I-speed charge?
Old 01-22-2004, 11:24 PM   #4
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I got no clue were are u located? theres other places that will do the swap
Old 01-24-2004, 09:03 PM   #5
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
Default it can be done...
You have to have the COMPLETE wiring harness to match the motor, and the crossmember for the engine bay. You can probably run your tranny but would have to upgrade the clutch.
Oh yeah, be prepared to shell out at least $8,000 for the complete swap. Mine has topped $10,000
Kreeger is offline   Reply With Quote
Old 01-25-2004, 03:06 AM   #6
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
If you're talking about the USDM STi (2.5L), that motor uses a fly-by-wire throttle, so you'll need to accomodate for that. I'm not too sure on the details of what you'll need though. You will probably need the STi pedal assembly, or there might even be a relay or microcontroller for it, if you're unlucky.
If you're talking about the JDM STi setup (2.0L), this shouldn't be an issue.
-s-
scotty305 is offline   Reply With Quote
06 STi Motor into and 04 STi, what problems will I run into? stillillmatic7 General Community 1 05-01-2007 06:52 PM
Swapping an sti motor into a 99 legacy? Wobble Newbies & FAQs 0 12-12-2006 05:36 PM
04 STi motor into an 02 wrx Smoby Service & Maintenance 1 08-28-2006 10:35 PM
$2500 into an OBS OBSstyle Normally Aspirated Powertrain 14 11-22-2003 04:46 PM
Forester STI II seats into an obs? Mgardenier Interior & Exterior Modification 6 09-17-2001 09:21 AM
