#1 |
Member#: 12408
VIC
Vehicle:2000 Toyota Hilux SR-5 TD |
I recently got my car back from the bodyshop, where they replaced the front bumper. Now the foglight pattern looks weird - there's a very noticeable vertical beam in the pattern. Is it possible to mount the foglights 90 degrees the wrong way? It's definitely not the aiming, the pattern is there regardless of how the lights are aimed.
#2 |
John Wayne Toilet Paper
Moderator Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 Black Mica |
they COULD have mounted the left lamp on the right side and vice versa...
that would severely mess up the pattern |
#3 |
Member#: 16200
Vehicle:tic- toc the countdown has started |
Yep.....it should say 'Subaru' at the bottom...not the side of the light.
#4 |
yeah if the pattern is vertical, the fog is mounted on the wrong side....
#5 |
Member#: 12408
VIC
Turns out the morons had swapped the left and right lights, and to make them fit, turned them 90 degrees. All better now
#6 | |
told you so ![]() |
