Old 01-23-2004, 11:14 AM   #1
Geoff
Warden of NASIOC Timeout
Super Moderator
Member#: 592
'11 X5 xDrive35i
'09 135i 6MT/'15 GTI 6MT
Question '01 RS Tranny vs. STI Type RA Tranny
On the quest to have the OBS's 2.2l replaced with a 2.0l USDM WRX engine, I've been reading in various posts that the RS tranny is about as reliable as the WRX's tranny. (I'm guessing 2003)
I've got the tranny out of an '01 RS in my OBS including rear LSD. The only problem I'm having is that the fourth gear sychro grinds a bit when at about 5500RPM, shifting into 5th.
That being said, would I be better of keeping my gearset and having the 4th gear syncro replaced, or replacing it with the STi Type-RA tranny? What are the advantages/disadvantages of one over the other?
Thanks,
Geoff
Geoff is offline   Reply With Quote
Old 01-23-2004, 11:52 AM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
It's a no brainer really; if you have the money then go with a Type-RA or better.
Here's why:
The RS and WRX gears are really no different aside from gear ratios. There are bonuses in having the 4.111 final drive of the RS, but that can be changed on a WRX transmission. Type-RA is typically a better final drive but will probably be changed if you convert your RS tranny to it. From gear to gear it will be better ratios as well.
The real difference is in the gears themselves. The Type-RA has hardened gears that are significantly stronger than the gears we get in the WRX or the RS. It may not take the abuse of serious horsepower, but it is a good step in the right direction.
Your problem sounds a lot like the problem I had in my 2000 RS. It turned out there was a nut inside the transmission that was improperly torqued causing excessive wear on the 5th gear synchro. At higher RPMs, the shift from 4th to 5th caused grinding. It was fixed under warranty, but that's not exactly useful to you
-Jon
Old 01-23-2004, 12:02 PM   #3
Geoff
Super Moderator
Member#: 592
'11 X5 xDrive35i
Jon -
From what Rallispec told me, lots of people have been happy keeping the 3.9(?) final drive in their WRX and moving to the Type-RA gearset. Granted the Type-RA is normally running a 4.44 final drive, teh 4.11 should be excellent from what I'm told. I just haven't seen any figures or posts anywhere that've shown that the STi gearset is any stronger than what we have here. Logic would state that it would be, but logically the WRX would have a stronger gearset than the RS...which isn't the case.
Oddly, the RS tranny didn't feel much different than my OBS tranny before it...though having the rear LSD is nice.
Old 01-23-2004, 12:15 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Taken from www.rallispec.com
Factory Ver.6 STi and STi RA 5-speed close ratio gearsets with special cryogenic stress relieving treatment. Improved strength and durability over stock WRX components. 1st & 2nd gear width increased by approx. 1mm vs. standard WRX. Gear tooth root thickness also increased substantially on most gears as shown in the picture. Excellent for mildly tuned street and group N competition vehicles.
There have been other threads, but I can't find them right now.
The rear LSD had a profound difference on my EJ22 and WRX transmission. I could forsee me blowing up an open diff with my EJ20 now, though. Now I want a front LSD
-Jon
Old 01-23-2004, 02:03 PM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
i've been there done that
boyfriends car
we cracked open his OE tranny
and replaced the gears with STi gearset.
my god there is a MASSIVE difference guys...
gears in the STi tranny are 10x thicker...
damn i should have taken photos.. i know i know...
what rallispec has stated is spot on.
this gearbox went into an SCCA Rally car that's rallied HARD!
no issues or problems to date (1.5 years later!)
hope this helps.
Jamie
www.subiegal.com
Old 01-23-2004, 04:09 PM   #6
Geoff
Super Moderator
Member#: 592
'11 X5 xDrive35i
hope this helps.
Jamie
www.subiegal.com
So is this a vote from Jamie to go with the Type-RA gearset?
Old 01-23-2004, 05:30 PM   #7
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Here is what Jamie is talking about.
(Photo from Rallispec)
I'm planning on the STi ratio instead of the RA.
Wedge is offline   Reply With Quote
Old 01-24-2004, 09:21 AM   #8
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
here is a question I have, not to highjack the thread but on the topic of trannies. anyways here goes, with a 2.5 tranny. what is the max power or daily drivable power with a USDM WRX conversion can it handle? Thanks
benjaminetanyahoo is offline   Reply With Quote
Old 01-24-2004, 01:14 PM   #9
Geoff
Super Moderator
Member#: 592
'11 X5 xDrive35i
From what I've heard (and witnessed) lots of it has to do with both the transmission's initial build quality and your driving style. More the latter than the former usually. I've heard of people breaking both with stock power (both the RS and WRX trannies) yet others who mod their RS and WRXes up big-time and still have their stock trannies. Sorry I don't have an answer...I'd say it depends.
I initially asked my question because I know the WRX and RS trannies are of the same caliber...was curious as to if the STi-RA tranny is really that much stronger. I guess it is.
Old 01-25-2004, 11:10 AM   #10
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
OMGHi2U RA Trannies
We have Taken Sti and WRX Trannies apart Sti gears are not only Thicker and beefer the Metal has been harden, and it take alot to destroy!
If your thinking about Swapping to a RA Remember All RA we get have the DCCD electronic center diff. Another Bonus!
Kevin
gr8wheels is offline   Reply With Quote
Old 01-25-2004, 12:07 PM   #11
Geoff
Super Moderator
Member#: 592
'11 X5 xDrive35i
Default Re: RA Trannies
Kevin
Actually, I'm planning on having Rallispec install the RA gearset into my RS transmission housing. It's a bit more economical than going with an all-out RA tranny.
Old 01-27-2004, 12:55 AM   #12
gr8wheels
Vendor
Member#: 20081
JDM IMPREZA's
Gr8wheels.com
OMGHi2U
Here Kitty kitty kitty.
No Really Very cool! you will be happy!!
Kevin
Old 01-27-2004, 02:40 PM   #13
Geoff
Super Moderator
Member#: 592
'11 X5 xDrive35i
Kevin
That is, unless you can get me a Type-RA tranny with DCCD for $1500-$1700.
Old 01-27-2004, 02:40 PM   #14
Geoff
Super Moderator
Member#: 592
'11 X5 xDrive35i
Kevin
JDM V6 STi Type-RA tranny...4.44 supasweetr34skyline Drivetrain 23 09-25-2009 09:46 AM
Sti Type RA gearset vs. JDM Sti Type Ra gearset russtafari Transmission (AT/MT) & Driveline 4 08-22-2008 11:04 PM
STI Type RA 5 speed tranny? STUDAndring Transmission (AT/MT) & Driveline 9 12-15-2004 10:50 PM
BMW M3 CSL vs Porsche GT3 vs Subaru STi Type RA Spec C xxtwowheelfiendxx Proven Power Bragging 5 12-21-2003 01:08 AM
Part number from STI type RA tranny... got the #, but can't find how to verify it JSiwek Transmission (AT/MT) & Driveline 55 07-31-2003 09:11 PM
