Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 01-23-2004, 11:58 AM   #1
GC84ever
Member#: 50433
2001 Impreza 2.5RS
BDP
Default Pros & Cons of having hood and trunk triggers connected to the alarm system?
I'm getting a compustar alarm system (2WFM) in my car next week.
I was wondering what are the Pros & Cons of having hood and trunk triggers connected to the alarm system?
GC84ever is offline   Reply With Quote
Old 01-23-2004, 12:22 PM   #2
Legacy
Member#: 10188
2007 Forester XT
Pro - easy way to defeat your alarm is to disconnect the battery, if someone can pop your hood without the alarm going off you'll never hear the alarm.
Con - Use strong metal pins or the factory pin if its lubbed properly. Plastic pins bend after a while, plastic gets "metal fatigue (plastic fatigue ?) and a bent pin will trick the alarm into thinking the hood has moved triggering the alarm.
- Using the factory pin , if its sticky will produce the same result.
IN the end I call it a "must" do as leaving those areas unprotectd just gives the thief an easy backdoor into your car.
Legacy is offline   Reply With Quote
Old 01-23-2004, 01:26 PM   #3
GC84ever
Member#: 50433
2001 Impreza 2.5RS
BDP
Thanks for the reply.
I wanted to ask someone else besides the installer for reasons; since it means more money for them.
Thanks
Old 01-23-2004, 01:28 PM   #4
cnk
Member#: 10757
2013 BRZ Limited 6MT
If possible, try to get magnetic switches instead of standard pins. The magnetic switches are sealed and not as susceptable to the weather and wear and tear as mechanical pins.
Calvin
cnk is offline   Reply With Quote
Pros & Cons of U.S. - Israeli Relations rizzuh Political Playground 41 02-28-2010 05:01 PM
Pics of Carbon Hood and Trunk on 04+ White STi? jsavage Interior & Exterior Modification 2 06-08-2005 08:13 PM
The End of the Cold War & the Disintregration of the USSR... pros & cons? Asinine Political Playground 14 10-07-2004 07:17 PM
ERaab, other Evo guys... pros & cons of switching over? snvin Tri-State Area Forum 19 10-04-2004 06:19 PM
Pros & Cons of K&N vs. Amsoil Filters Button Normally Aspirated Powertrain 21 04-19-2003 03:06 AM
