Old 01-23-2004, 02:35 PM   #1
swol3
Member#: 44785
02 sedan wrx
WRB COBB stage 2
Default anyone using a FRAM sure drain plug?
was wondering if it works good. if it does im planning to buy it.
http://automotive.aubuchonhardware.c...ain-577245.asp
swol3 is offline   Reply With Quote
Old 01-24-2004, 06:41 AM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
It's OK, but I'm pretty sure they don't make one in Subaru size. Get a Fumoto valve instead.
Old 01-25-2004, 02:22 AM   #3
cvalle-sd
Member#: 420
2001 Cr-V
I'm on the Fumoto bigtime - makes oil changes much faster.
Get that bad boy.
cvalle-sd is offline   Reply With Quote
Old 01-25-2004, 01:02 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I heard they don't make em in our size yet.
Fumoto>Fram Sure Drain
Old 01-25-2004, 04:34 PM   #5
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Yep, love my Fumoto drain valve.
drees is offline   Reply With Quote
Old 01-25-2004, 04:41 PM   #6
swol3
Member#: 44785
02 sedan wrx
WRB COBB stage 2
in canada they do make it for a 02 wrx. but since u guys like the
Fumoto drain valve so much i will buy one of those puppies.
Old 01-25-2004, 06:27 PM   #7
InfamousDX
Member#: 25413
If they only had something to make the oil filter removal now...
Old 01-26-2004, 07:56 AM   #8
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
I have a suredrain, drains slow but it makes life easier
overdose is offline   Reply With Quote
Old 01-26-2004, 11:26 PM   #9
SupaSizeFries
Member#: 10088
2002 Wrx Sti back
from the Dead
SupaSizeFries is offline   Reply With Quote
Old 01-27-2004, 01:37 PM   #10
sonicblue
Member#: 25227
2012 Escape
Latex glove and do it really quick
Actually, I heard the tip of puncturing the filter with icepick/awl or something. Let it empty that way, then remove. Frankly, the latex glove is easier and faster (even helps protect the hand if the oil is a little too warm....)
sonicblue is offline   Reply With Quote
Old 01-27-2004, 09:52 PM   #11
SupaSizeFries
Member#: 10088
2002 Wrx Sti back
from the Dead
I'll use gloves and unscrew the filter part way and let the oil drain into a container. Once it stops dripping, I take the filter completely off and carefully dump the contents into my oil container. Takes more time but cuts down on the mess.
Old 01-29-2004, 11:07 PM   #12
Woody643
Member#: 34739
03 WRX
Silver Metallic
Default Fram
Anything FRAM will be sure to drain the plug right out from the bottom of your WALLET!!!
Woody643 is offline   Reply With Quote
Old 02-01-2004, 12:42 AM   #13
PeterJ
Member#: 14727
2002 impreza RS
haha. I use fram oil filters because theyre cheap and I change them often. I wish they made the sure drain in our size because I think that the fumoto valve sticks out too far. I use a skidplate but I would still want something low profile. Maybe I can machine a small adapter...
PeterJ is offline   Reply With Quote
Old 02-23-2004, 02:14 PM   #14
RSEnigma
Member#: 32326
'04 S2000
Suzuka Blue
i hav a "claw" for the filter. i work at a dealership so i do oil changes like there's no tomorrow. its a cool little device that goes on the end of a 3/8" ratchet and auto tightens while u twist. i got it from the snap on guy so i don't remember how much it was or where u can get it.
RSEnigma is offline   Reply With Quote
Old 02-26-2004, 10:36 PM   #15
iceNine
Member#: 12170
2002 WRX Sedan
Platnum Silver Metallic
I also use one of those spring loaded self tightening "universal" filter tools. A good choice if you have several different cars with different sized filters to change. Bought mine at PepBoys. It is a Lyle I think.
The Fumoto valve is great. I have one on my oil pan and also on the drain for my auto trans pan as well since they use the same size plug. Works great for both.
Dale
iceNine is offline   Reply With Quote
Old 02-27-2004, 10:45 PM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Fram filters will be the death of your car, especially when OEM equivalent purolators (generic brand) can be had at Pep Boys for 3$
Using a torque wrench on drain plug Drew303 Service & Maintenance 19 06-18-2009 10:55 AM
Anyone use Fram Oil Filters for Sti? wanalaugh74 Mid Atlantic Impreza Club -- MAIC 10 08-24-2007 04:50 PM
Anyone use the Fram Airhog filter? civichunter2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 12-25-2004 06:38 PM
Anyone local selling large alum skidplate w/access to drain plug and filter rally_wannabe Mid Atlantic Impreza Club -- MAIC 1 04-16-2003 11:27 AM
Fram Sure Drain? Kevex Service & Maintenance 1 04-29-2002 11:55 AM
