Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 01-23-2004, 03:43 PM   #1
Member#: 48099
2000 Forester
Default Did I pop the cigarette fuse?
I was using a power inverter the other day in the lighter socket in the front and suddenly it stopped working. I thought the inverter died, but when I hooked a meter up to the socket in the car there is no voltage any more coming out of the lighter socket. It's dead. The heated seats don't work now as well which makes sense as I understand they are tapped off the lighter socket. Where is the fuse for this? I checked everything in the main fuse pannel under the hood and they were all fine. Am I missing another fuse pannel somewhere? Oh, it's a 2000. Thanks!
toonman is offline   Reply With Quote
Old 01-23-2004, 03:54 PM   #2
Subie Gal
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Yep. there's another fuse box...
Inside the car
- dash
Left hand side...
below and left of the steering wheel
there is a "pocket / flap" there
open it...
then carefully remove it (should pop right out)
ta da
fuses should be there
and back of that pocket -
you shoud find the fuse labels indicating what's what.
hope this helps.
Help: Popped sbr-1 fuse... use your imagination ;) ocelot21 North West Impreza Club Forum -- NWIC 3 02-14-2009 03:22 AM
Did I Pop a Head Gasket?? nperkins Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 08-14-2008 03:17 PM
TSD: When did you pop your cherry? Domokaru General Community 14 02-28-2008 09:58 AM
Did Greddy gauges blow a fuse or is it just a ghetto install? CrazyBabyDoc Electrical & Lighting 2 01-19-2005 03:58 PM
Auto peoples: Ever pop in the FWD fuse? RawCode Transmission (AT/MT) & Driveline 18 01-16-2003 02:18 PM
