Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds
Old 01-23-2004, 05:04 PM   #1
PolTec Inc
Vendor
Vendor Sales Rating: (2)
Member#: 41768
Smile We're Back, Look Here for our Sway Bar Links, now also for the STi
Hi All,
We are back after a short Christmas brake, and this time we have our own web site (although it is still long way from being finished yet) where we will sell from now on.
Get our Front links for Impreza and WRX (wagon and sedan) HERE.
Or our rear links HERE
Featuring:
- Adjustable rear links (unfortunately we had to raise prices on those) with spherical bearings.
- Regular links with spherical bearings, and
- Combination links with plain poly bushings on one side and spherical bearings on the other.
All of our spherical bearings now have rubber seals for added protection keeping the lubricant inside and debris and water out. No one can match that.
Just added:Rear STi Links
AND
WRX Sedan adjustable front links with twice the strength of the stock links.
Enjoy and let us know if you have any questions.
Dariusz
PolTec Inc.
PolTec Inc is offline
Old 01-23-2004, 08:02 PM   #2
Bolster
Member Sales Rating: (26)
Member#: 22290
2002 WRB WRX Wagon
Just paypaled you for set of fronts.
Bolster is offline
Old 01-24-2004, 05:27 AM   #3
nhluhr
John Wayne Toilet Paper
Member Sales Rating: (22)
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
i need a set of rear swaybar endlinks that will fit the PINK sti lateral links. They normally look like this:
Any solutions??
nhluhr is offline
Old 01-24-2004, 06:25 AM   #4
lobelsteve
Member Sales Rating: (3)
Member#: 31992
2007 STI
UGM
You call those red things front links ?
No way would I put those under my car where they could get dirty and none would see them.
I might need a set to keep on the coffee table as they are so pretty. Or I could jack up my car so people could see them better.
Beautiful links.
lobelsteve is offline
Old 01-24-2004, 08:14 AM   #5
PolTec Inc
Vendor
Member#: 41768
Thanks Guys,
Bolster, your links will ship today.
nhluhr, I am 99% sure we can do this, I sent you a PM.
Lobelsteve, you had me going there for a short while, but thankfully, my quick reading skills saved me from falling into rage . We recomend that you hang your car from the sealing in your living room so that all the suspension can be clearly visible.
Dariusz
Old 01-24-2004, 12:38 PM   #6
typer_126
Member Sales Rating: (8)
Member#: 14377
2004 STi
Twin Scroll Goodness
Bump, for the STi front links.
typer_126 is offline
Old 01-24-2004, 06:58 PM   #7
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Poltec -
i'm so glad to hear you can make me a rear STI-pinkbit swaybar link!
I want it with full pillowballs, like the front wagon link.
Here are some more pictures to help you with the design:
nhluhr is offline
Old 01-24-2004, 07:19 PM   #8
Bolster
Member#: 22290
2002 WRB WRX Wagon
Dariusz
Great- I'll be glad to tell everyone how they work. They look just beautiful. I figure I'll adjust them to stock length first. I'm running coil overs, but not lowered much.
Bolster is offline
Old 01-24-2004, 08:03 PM   #9
ExitVisa
Member Sales Rating: (4)
Member#: 15276
2003 WRX
Default Re: We're Back, Look Here for our Sway Bar Links
Get our Front links for Impreza and WRX wagon HERE.
Dariusz
PolTec Inc.
I'm a little confused. It says the front links are for the Impreza and WRX wagon, but the description on your site says, "Fits: Subaru Imprezas RS, 2.5RS, L, and Legacy (does not fit STi or WRX) " My question is, will they fit a WRX or no?
<Am I reading this wrong? It wouldn't be the first time that's happened>
ExitVisa is offline
Old 01-24-2004, 08:16 PM   #10
PolTec Inc
Vendor
Member#: 41768
Well, it looks like I have some correcting to do. To answer your question, they fit WRX wagon but not sedam.
Old 01-26-2004, 07:54 PM   #11
PolTec Inc
Vendor
Member#: 41768
Check out above just added STi rear links and WRX front adjustable end links.
Old 01-27-2004, 03:59 PM   #12
PolTec Inc
Vendor
Member#: 41768
TTT
Old 01-27-2004, 04:57 PM   #13
gotsol
Member#: 17346
08 Cayman S
Interested in the front adjustable links for WRX sedan.
Please help me understand two things.
1. what advantage/purpose does having an adjustable front endlink do for me? Will I do more harm then good with my set-up if they are adjusted inproperly.
2. How are these an advantage over the traditional poly bushing type.
oh and 3. will it work well with a perrin adjustable front sway bar.
thanks
Patrick
gotsol is offline
Old 01-28-2004, 06:16 PM   #14
PolTec Inc
Vendor
Member#: 41768
Patric,
1. Out of the box, our links are set for stock height, so you can simply mount and enjoy them. The adjustment is there to eliminate preload of the sway bar. Due to part differences, your sway bar may need to be forced to fit links that are the same length on both sides and that causes preload effectively making your suspension uneven. With our links, you can make one of the links longer to eliminate that preload.
2. The spherical bearings do not compress like bushings do giving you linear sway bar response and, at the same time, they handle misalignment with no restrictions eliminating side forces on control arm and sway bar so your sway bar acts only to level your car.
3. The links have all critical dimensions the same as stock, so if you can use stock links you can use ours as well.
I hope that answers your questions.
Dariusz
PolTec Inc
Old 01-29-2004, 03:03 PM   #15
PolTec Inc
Vendor
Member#: 41768
Unforunatelly, we just sold out front STi/WRX Sedan links and rear STi links. We will have them available on 2/7. If you want you may preorder them now and they will ship that day.
Old 01-29-2004, 07:09 PM   #16
PolTec Inc
Vendor
Member#: 41768
ttt
Old 02-03-2004, 10:04 AM   #17
Bolster
Member#: 22290
2002 WRB WRX Wagon
I put mine in yesterday. They look great, and they work great. I used white lithium grease to grease the bearings. What grease do you guys use for these?
Bolster is offline
Old 02-04-2004, 01:39 AM   #18
Sputnik 5
Member Sales Rating: (5)
Member#: 27680
2002 Impreza WRX
will the rear STi links work on a WRX?
Thanks
Sputnik 5 is offline
Old 02-04-2004, 10:23 AM   #19
sochico
Member#: 18377
2002 wrx
midnight black
what is the advantages of a solid rear endlink to an adjustable
luis
sochico is offline
Old 02-04-2004, 11:45 AM   #20
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
does this come w/ all necessary nuts and bolts?
im missing a bolt on one of my end links and i might use this as an excuse to upgrade
spankaveli is offline
Old 02-04-2004, 01:55 PM   #21
Bolster
Member#: 22290
2002 WRB WRX Wagon
My front links came with EXTRA hardware- a really nice touch in case you manage to lose something.
Bolster is offline
Old 02-06-2004, 07:12 AM   #22
PeteDucati
Member Sales Rating: (1)
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Does anyone know if the STi links (rear) will work on the WRX yet? I may have an issue with my rear swaybar smacking my exhaust once the car is lowered a bit so I'd like to get the adjustable links (perferably the STi style) BEFORE I lower the car.
Ps. Is Dariusz on vacation?
PeteDucati is offline
Old 02-06-2004, 11:57 PM   #23
BIGSKYWRX
Member Sales Rating: (102)
Member#: 7958
09 GH B+
They won't work unless your willing to swap some parts- namely the rear lateral links (has different mounting point) and sway bar-it's a slightly different shape.
A person may be able to have some weld on the "tab" in the correct spot- you'd want to have a STi one in your hand or good pics/measurements.
The other possiblity is building a "box' like the pink STi utilize, again you'd want one hand to replicate it.
I'll bet Dariusz could come up w/ a little "box" that would work.
Big Sky
BIGSKYWRX is offline
Old 02-08-2004, 09:51 AM   #24
PolTec Inc
Vendor
Member#: 41768
Hi,
I am back, now, here are the answers:
No, they will not, if you want the adjustability in the rear you need to buy the WRX rear adjustable links. Unfortunatelly they are much more expensive.
The same as for the front (see few posts above for detailed explanation), it simply eliminates sway bar preload.
All of our products come with all necessary hardware plus some extra just in case.
Big Sky,
Thanks for your help, you are 100% correct, and in fact we are in a process of designing the "box". I will keep you posted on this.
Dariusz
Old 02-08-2004, 03:40 PM   #25
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
I ordered the adjustable rear links for the WRX. How much shorter are they than the Perrin links when adjusted to the shortest setting? I'm afraid of how close the sway bar will be to the exhaust once the lowering springs go in.. hence the need for adjustable rear links.
Thanks.
WTB: catless down pipe, cobb front sway bar, and sway bar links Chadsti Private 'Wanted' Classifieds 5 03-04-2010 02:51 PM
bolt size for front sway bar link? Trademark Brakes, Steering & Suspension 2 11-23-2008 10:39 PM
Looking for stout mounts for rear sway bar.... 05Scooby Private 'Wanted' Classifieds 1 03-07-2008 11:13 AM
Will end links upgrade be needed for cobb sway bars? KY Archetype Brakes, Steering & Suspension 6 08-06-2005 09:40 AM
For Sale : Sway bar Link (Front and rear) (for canada only) Mike Moffa Canada Region Forum 3 07-30-2000 08:33 PM
