Old 04-15-2001, 02:27 PM   #1
gaylemd
Member#: 2643
2001 2.5 RS
BRP
Post Underground Upgrade Report
Well, I just finished the Magnecor wires and Iridium plugs. I have "three words" for you--fab...u...lous! I'm getting ready for next weekend. I'll be instructing at Summit Point, West Virginia for the BMW Car Club. I hope to get the front 22 mm swaybar on before then. I put the 20-24mm Whiteline on the rear at a Scooby Day put on by Richard West down at Virginia Motorsport Park. I won't be able to use the 22mm or 24mm setting without it. The car is definitely more neutral with the 20mm setting and the stock bar upfront and would be prone to excessive oversteer if it were any stiffer without the bigger bar up front. I got a chance for a "before and after" run of a fast slalom that he set up. Well, time to put the foglight covers on. C Ya!
Mike Gayle
gaylemd is offline   Reply With Quote
Old 04-15-2001, 02:42 PM   #2
2.5rsMI
Member#: 3270
2001 Impreza RS
BRP
Post
Where did you get your wires?? How much did you get them for??
2.5rsMI is offline   Reply With Quote
Old 04-15-2001, 04:09 PM   #3
KapaFool
Member#: 2679
2010 WRX4FD
Post
where oh where??
KapaFool is offline   Reply With Quote
Old 04-15-2001, 06:56 PM   #4
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
I see that primm has the wires. Check the vendor section.
Peaty is offline   Reply With Quote
Old 04-15-2001, 08:29 PM   #5
gaylemd
Member#: 2643
2001 2.5 RS
BRP
Post
I got them directly from Magnecor. They fit perfectly and have the same components as stock. I'd been told that they don't seat properly, too long, too short, yada, yada. But, mine were perfect. Just go to their website at http://www.magnecor.com/
Mike Gayle
Old 04-15-2001, 11:00 PM   #6
Digital_Boy
Member#: 730
Post
Mike,
Where did you find the front bar for a 2.5RS? As far as I knew, the only aftermarket front bars were designed for the EJ20 turbocharged cars, and would not fit the front crossmember on a 2.5RS.
Thanx
Digital_Boy is offline   Reply With Quote
Old 04-22-2001, 11:51 AM   #7
gaylemd
Member#: 2643
2001 2.5 RS
BRP
Post
Digital_Boy,
PM'd you.
Mike
This is going to get a lot of you bent out of shape. RE: Brake upgrades Davenow Newbies & FAQs 698 09-20-2016 11:57 AM
Stoptech Brake Upgrade Report GarySheehan Brakes, Steering & Suspension 28 07-06-2002 07:43 PM
Underground Upgrader needs help gaylemd Mid Atlantic Impreza Club -- MAIC 15 04-17-2001 12:43 AM
('93-'01) The Underground Upgrader Strikes again gaylemd Impreza Forum 3 04-12-2001 08:02 PM
