Welcome to the North American Subaru Impreza Owners Club Saturday November 21, 2009
Old 01-24-2004, 04:58 PM   #1
RyaNCSU1
Member#: 52443
Default Radar detector
Im wiring my radar detector up shortly and i figured i would run it into the clock. The problem is im not sure how the clock shroud comes out on an 04 Sti. Im sure it just pops out but im trying to find out if you need to pull it up from the back, sides, front, whatever.
Obviously i dont want to break it
Any help is appreciated thanks.
RyaNCSU1 is offline   Reply With Quote
Old 01-24-2004, 05:32 PM   #2
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
IF I remember correctly, it has 2 clips in the front, near the edges and 2 (?) clips in the rear.
Use a flat screwdriver (with a towel to cover the end) and SLOWLY pry one front edge up slightly, then the other side, then back, etc. ...do this carefully and the back will move enought for you to be able to unclip the whole thing.
Be careful, but it is meant to be a peice that can be taken off and on more than once.
mike m
bezerk is offline   Reply With Quote
Old 01-24-2004, 06:57 PM   #3
DrD
Member#: 22412
2002 WRX Sport Wagon
Platinum Silver Metallic
I would recommend against using a screwdriver from the top - it takes nothing to scratch/dent the dash (unless that doesn't matter, in which case have at it) - removal of the clock is easy - either pull it straight up and out (you have to pull pretty hard) - or remove the trim/vent assembly in the center of the dash, then use a screwdriver to push the two hooks on the front of the clock off, then lift it up and out.
Old 01-24-2004, 07:49 PM   #4
ydant
Member#: 43447
2009 STI
The Good Grey
Pushing the hooks from underneath did nothing for me. What finally worked was pulling - HARD - much much harder than you think you need to. Maybe put some wiggle into it, too.
Cheers,
-y
ydant is offline   Reply With Quote
Old 01-24-2004, 10:47 PM   #5
Uncle Scotty
Member#: 16200
tic- toc
the countdown has started
I gave up on the damn clock, and wired mine to the plug for the compass/mirror and was done with it.
Old 01-24-2004, 10:50 PM   #6
c_hunter
Member#: 32434
05 Outback XT 5EAT
Gold/Black
c_hunter is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 05:25 PM.
