Old 01-24-2004, 06:42 PM   #1
Erudition
Member#: 7560
Default Morettes Broken, need help (56k beware)
Ok, I got my used morettes in the mail, and one of the projectors is broken. (See pics)
Where can I get a replacement?
I called allsubaru.com and they said I will have to wait around 3 weeks.
These have the "angel eye" mod as well.
Also, I have heard of a leveling motor. Is this similar to the sti hid leveling motor and switch? Or is it something different? And who sells these things?
Thanks.
Erudition is offline   Reply With Quote
Old 01-24-2004, 06:59 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Try Z1, www.z1auto.com , they are a Morette dealer and should be able to get you the projector unit. Can't say if they have it in stock though, you may still have to wait.
The Morettes do have provision for a leveling motor but I've never seen one on Morettes sold in the US, I think they are only used in the overseas versions.
Old 01-24-2004, 10:25 PM   #3
SleeperWRX
Member#: 8179
yup I got my morettes and a replacement projector from Adam at Z1. he's your go to guy
-Mike
SleeperWRX is offline   Reply With Quote
Old 01-24-2004, 11:12 PM   #4
RexX
Member#: 7092
2002 WRX Wagon
My Morrettes came with leveling motors. I removed them before I installed the lights. It makes access to the headlamp adjusting screws much easier. Keep in mind that the leveling motors are designed to only lower the headlights. When used properly, the headlights are aimed properly with the leveling motors in the full up position and then lowered when you have a load in the back of the vehicle. On cars equipped with factory HID lamps, this is done automatically using a ride height sensor of some sort. Usually it is linked to the rear suspension. I've seen some manually controlled units on old Euro-spec Mercedes. Of course, this is before the advent of HID lamps. All this is to prevent you from blinding oncoming traffic.
RexX is offline   Reply With Quote
Old 01-24-2004, 11:16 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Interesting, that's the first reference I've seen to anyone with Morettes having the leveling motors. Where did you get yours from, and are they LHD?
Old 01-24-2004, 11:24 PM   #6
RexX
Member#: 7092
2002 WRX Wagon
They are LHD and I purchsed them through an i-club group buy. (Befor it became NASIOC.) If I remembr correctly, the person running the group buy sourced them directly from Europe.
Helping a friend clean up old photo's... need help. 56K no no 4x4GGG Off-Topic 18 02-02-2005 11:04 AM
Morettes wiring need help voyagerman Electrical & Lighting 11 06-08-2004 07:04 PM
Morettes broken, need help. (56k warning) Erudition Southern California Impreza Club Forum -- SCIC 8 01-25-2004 01:36 PM
My nitrous is broken, need help ASAP IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-17-2003 11:32 PM
Busted Morette Lense...need help TXBlueBeast Interior & Exterior Modification 4 01-26-2003 02:24 AM
