Old 01-25-2004, 03:18 AM   #1
Genner
Member#: 18372
Default which is a better hid kit
MuCulloch HID or phillips Hid
Genner is offline   Reply With Quote
Old 01-25-2004, 07:18 AM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
phillips is the HIGHEST quality you can get.
nhluhr is offline   Reply With Quote
Old 01-25-2004, 08:38 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Phillips doesn't make kits, they make the HID components (ballasts, bulbs). Kits using Phillips or Hella electronics, and also German bulbs, are of much higher quality than those using cheaper Asian ones. Of course it's getting harder to find aftermarket HIDs now that NHTSA has been enforcing the ban on them and many vendors no longer carry them.
Old 01-25-2004, 04:00 PM   #4
kungfooren
Member#: 43437
2004 WRX wagon
Java Black
yeh. philips is great. muccolluch is actually really good. you'd be surprised. plus, it's dogg a$$ cheap.
i reallly don't know where you can find a philips kit. try ebay?
kungfooren is offline   Reply With Quote
Old 01-25-2004, 07:44 PM   #5
Genner
Member#: 18372
so is there any difference between the MuCulloch and phillips ballast? Are they pretty much comparable such as connectors, replacement bulbs, quality?
Old 01-25-2004, 07:51 PM   #6
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Quality seems to be better with the Philips unit.
Hank3 is offline   Reply With Quote
Old 01-25-2004, 08:50 PM   #7
Subie2.5RS2003
Member#: 41941
2003 Impreza 2.5RS
Ridge Blue Pearl
phillips does not make kits ... they make systems for car (benz, bimmers etc) all of those kits are pieced to gether and get a phillips sticker put on them.
hidplace.com
Subie2.5RS2003 is offline   Reply With Quote
Old 01-26-2004, 02:50 AM   #8
4npower
Member#: 9018
02 WRBP WRX
Slvr 06.5 Jeep Grnd SRT8
Witch has a better beam pattern >?
4npower is offline   Reply With Quote
Old 01-26-2004, 05:00 AM   #9
Genner
Member#: 18372
can you swap between a phillip's ballast bulb with a muCulloch ballast bulb? If you can't, why not?
Old 01-26-2004, 08:44 AM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Depends on the output wiring of the ballast. OEM-type ballasts such as Phillips or Hella will usually have a cable with a standard D2-type bulb connector which fits OEM-type D2S or D2R bulbs. Aftermarket ballasts/ignitors and bulbs use wire leads with different connectors so they are not interchangeable.
Old 01-26-2004, 03:17 PM   #11
Genner
Member#: 18372
would you happen to know if the MuCulloch ballast have the same connectors at the hella/phillips ballast?
Old 01-26-2004, 08:34 PM   #12
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I don't think so, but you'd have to actually compare them to be sure.
Which is the better Choice? Camshafts or Header? Cusco Normally Aspirated Powertrain 30 01-22-2002 12:44 PM
which is the better deal here? TurboWRX Car Audio, Video & Security 3 07-13-2001 10:38 AM
Which is the better brake setup? Skidd Brakes, Steering & Suspension 10 01-24-2001 11:42 AM
