Old 01-25-2004, 11:24 AM   #1
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Default Best way to remove the pins out of ECU harness?
Need to do this so I can finish up my JDM swap. TIA.
Need4Boost is offline   Reply With Quote
Old 01-25-2004, 11:41 AM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Dental Pick
Drac9 is offline   Reply With Quote
Old 01-25-2004, 02:20 PM   #3
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
snap on makes a beautiful pick tool that will help.
I use it exclusively on Honda ecu's and it has never let me down.
steve is offline   Reply With Quote
Old 01-25-2004, 05:18 PM   #4
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
What about the pins on the engine harness? They appear to have plugs on them as well?
Old 01-25-2004, 10:39 PM   #5
cronic
Member#: 9749
What do you have left to do to complete the swap? What harness are you using JDM?
cronic is offline   Reply With Quote
Old 01-27-2004, 12:58 PM   #6
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Just fab up an oil line to my turbo and do the wiring. Then it needs to be tuned and its all set.
Old 01-27-2004, 02:55 PM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I have a dental pic of sorts and I was unable to remove a single pin from the ECU plugs. I could remove any pins from any of the other harnesses except for airbag though. We tried a needle, the dental pick, and a couple other things I believe.
-Jon
Old 01-27-2004, 06:28 PM   #8
Richard Sierra
Member#: 29528
02 WRX wagon V7 RA
-C conversion
There is small lock on the connector that must be popped up. You can use a very small screwdriver to release it. Look closely, it is on the top of the connector.
Once the lock is "up" you can pull out the terminals from the back side of the connector. I used needle nose pliers to pull them out. I have never used a pick, but the lock must be released before they will come out.
Richard Sierra is offline   Reply With Quote
Old 01-27-2004, 06:40 PM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Are you going in from the front side and prying up the lock or going in from the back side and pushing up the lock?
-Jon
Old 01-28-2004, 12:28 PM   #10
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
-Jon
What ended up working for you? I have tried every pick I have and still no luck. What a PITA.
Old 01-28-2004, 01:15 PM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Nothing worked and I have given up for the time being. I need only ONE of those pins free so I can add it in a different spot.
-Jon
Old 01-28-2004, 06:36 PM   #12
Richard Sierra
Member#: 29528
02 WRX wagon V7 RA
-C conversion
-Jon
It is right on top of the connector. Look closely you will see a separate molded piece. Pry it up from the top (not from the front or back) using a very small screwdriver.
I'll shoot a pic if that is still not clear. Once you figure the lock out the terminals come out easy.
Old 01-29-2004, 12:39 PM   #13
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Pics please.
Pics are worth a million words.
Old 02-01-2004, 09:46 AM   #14
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
TTT.
Old 04-20-2012, 09:19 PM   #15
sk8boylou
Member#: 246669
2002 V8 EJ207 6pd
wish i knew this before i destroyed my terminal :-(
sk8boylou is offline   Reply With Quote
Old 08-13-2013, 02:48 PM   #16
fullCircling
Member#: 290547
here is a subaru .pdf that has pics of the part numbers for the terminals, as well as the tools.
http://techinfo.subaru.com/proxy/607...4760668812.pdf
fullCircling is offline   Reply With Quote
Old 08-13-2013, 05:48 PM   #17
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
If the subaru ones turn out to be really expensive, napa sells removal tools as well.
Cathexis is offline   Reply With Quote
What's the best way to get a dime out of the garbage disposal? Prod Off-Topic 36 07-23-2008 05:30 PM
Best way to pull the wrist pins? MasterKwan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-22-2007 01:52 PM
What's the best way to remove tint adhesive? Porter Interior & Exterior Modification 11 04-30-2003 01:03 PM
What's the best way to remove tint adhesive? Porter South East Region Forum 17 04-30-2003 07:35 AM
What is the best way to remove the clock housing? and tap wires for gauge lighting? NYWRXTASY Interior & Exterior Modification 10 11-03-2002 11:41 AM
