Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 01-25-2004, 01:34 PM   #1
Rickyh
Member#: 40453
Default How can I monitor idcs
Is there anyway to monitor injector duty cycles without a utec?
Rickyh is offline   Reply With Quote
Old 01-25-2004, 02:13 PM   #2
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
yeah I believe many OBD2 scanners can monitor this as well. I know mine can.
MustGoFast is offline   Reply With Quote
Old 01-25-2004, 06:03 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
There aren't any OBD2 scan tools that can monitor a WRX's injector duty cycle. The only standalone solution for logging injector duty cycles is DeltaDash from www.ecutek.com.
Jon [in CT] is offline   Reply With Quote
Old 02-05-2004, 11:25 AM   #4
MustGoFast
Member#: 33370
2002 Impreza WRX
exscuse me? The scan tool I bought reads the IDC from the ECU... I have to look and see what it is but it's not deltadash.. that is just one example of a scan tool... Mine does not have nearly that resolution though so would not be as useful for tuning but cost a heck of a lot less.
Old 02-05-2004, 03:07 PM   #5
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The SEC PSI^3 unit shows injector pulse width which is just one calculation away from IDC.
mbiker97 is offline   Reply With Quote
Old 02-05-2004, 04:17 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
Please do "look and see what it is." The WRX ECU doesn't report IDC to even a Subaru Select Monitor (the dealer's tool) or to DeltaDash. DeltaDash, however, can compute IDC from other data reported by the ECU when interrogating it using Subaru's proprietary (non-OBD2-compliant) communications protocol. If a scan tool relies solely on OBD-2 communciations protocols to interrogate the WRX ECU, it cannot report IDC.
Old 02-06-2004, 01:47 AM   #7
jlevy
Member#: 15696
2015 WRX 6 speed
Default alternate method
On a somewhat related note, you can monitor MAF values with some OBD-2 scan tools (I use a pocketlogger). Assume values for safe AFR, fuel density, injector size, and desired max IDC and you can easily come up with a maximum safe lb/min air flow target. Off the top of my head, I'd say it's somewhere around 26-28 lb/min for stock injectors.
...and no, my pocketlogger does not give any injector data.
-my 0.02
edited to add injector size to list of assumed values.
jlevy is offline   Reply With Quote
how can i lower idc acidrain088 Engine Management & Tuning 10 03-25-2008 08:56 AM
So how bad is 101% IDC? 94'325is Engine Management & Tuning 4 03-11-2008 09:25 PM
linux dual monitor setup: can 2 monitors have their own seperate workspace? enozto Off-Topic 2 01-15-2008 10:06 AM
What tools can look at IDCs? wcbjr Texas Impreza Club Forum -- TXIC 11 10-13-2004 01:31 PM
how can i lower my IDC wrspeed Engine Management & Tuning 18 01-21-2004 09:29 PM
