Old 01-25-2004, 02:17 PM   #1
Drowner
Member#: 49297
17 WRX Limited
Default Taking apart fogs
I installed some PIAA bulbs in my RS fogs and one popped immediately when i turned them on. It was just a defectove bulb. Anyway, the inside of the lens is all cloudy, atually more like dusty, and doesnt have the crystal shine like the other does. How can i take the lens off and clean it out? I saw 2 platic tabs on the sides, but after unclipping them, i still couldnt pull it apart. will i have to heat up the housing? Any help is apprer45ciated.
Drowner is online now   Reply With Quote
Old 01-25-2004, 11:52 PM   #2
c_hunter
Member#: 32434
05 Outback XT 5EAT
Gold/Black
Did you touch the bulbs with your bare fingers? If you get skin oils on the bulbs, they will burst when they heat up (not defective).
Craig
c_hunter is offline   Reply With Quote
Old 01-26-2004, 11:18 AM   #3
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
that sounds like what happened....as far as opening the fogs...yeah throught them in the oven and bake them the same manner you would a headlight...remember to move those clips BEFORE throwing them in the oven
ATX25RS is offline   Reply With Quote
Old 01-27-2004, 09:05 PM   #4
Drowner
Member#: 49297
17 WRX Limited
No, i didnt touch the bulb. I know about that. But thanks for the responses anyway.
Old 01-27-2004, 09:10 PM   #5
h1ghro11a
Member#: 24251
Default i just did this last week
Take the bulbs out, then bake them in the oven, i found 250 for 20 minutes worked well. 200 degrees just wasnt enough. Then take a flathead and work it in between the housing and glass where the tabs are(its a little thicker glass there) and wiggle it until it comes loose. Then work the glass off gently, careful with the screw driver, you dont want to force to much or else you might chip the glass.
To put back, I would suggest baking them again, then lay a thin layer of silicone in the housing and sqeeze! Put the clips back on! Done deal. Good luck
h1ghro11a is offline   Reply With Quote
Taking apart 04/05 Fogs cmcnamara Electrical & Lighting 9 12-28-2009 01:20 AM
Let's take apart mav1c's car and take the parts! Saturday December 27th mav1c Mid Atlantic Impreza Club -- MAIC 60 01-13-2009 02:48 PM
How do I take my fog lights apart? ToddZ199 Electrical & Lighting 10 03-26-2005 08:12 PM
How to take apart... Keiho Car Audio, Video & Security 4 12-05-2000 06:53 AM
