Old 01-25-2004, 06:51 PM   #1
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Exclamation HVAC problems!
Why wont my Ac turn on when I have the Defroster on? I have to press the button in order for my windows to not fog up.. and I have the thing set for outside air to come in...
This is on the Forester.. I can't rememember if it did this from the start..
SubaruImpreza_power is offline   Reply With Quote
Old 01-25-2004, 08:24 PM   #2
fredj
Member#: 13735
2002 Outback Sport
Sedona Red
It can't be much warmer in CT this week than NJ. One of the safety fetures built into the AC keeps the compresser from comming on when it is cold eneugh that you would otherwise get a slug of liquid rather than gasious refrigerant back to the compresser and distroy it. Try swiching to 100% outside air to dry off the windows. Heating outside air to the max should make it popcorn dry.
Fred
fredj is offline   Reply With Quote
Old 01-25-2004, 08:54 PM   #3
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
it did the same thing durning the summer as well.. It sucked when it was Humid out and it started raining..
Old 01-27-2004, 12:04 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Running on "recirc" is not the best idea when it is humid.
This means even when it is cold out. You have snow on you and the moisture in your breath which condenses on the inside of the windows.
As stated above, use the outside air setting.
Also, when the car is really cold, it probably disables the AC compressor until the coolant temp comes up to prevent stalling from the extra load.
Oh. Using "recirc" does not hurt anything, it is just not very efficient.
Old 01-27-2004, 01:12 PM   #5
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Yeah but it does not turn on Period when I turn on the front window Defrost
Old 01-28-2004, 02:36 PM   #6
bigpaulo
Member#: 17655
2002 Impreza TS
low profile green
Default make sure your AC is working...
My AC died this past summer, had it fixed under warranty (new expansion valve needed, plus some O-rings). So check that your AC is working at all (just what you want, crank the AC in the dead of winter!) But that should tell you if the AC is completely out, and not just the defogger part of it.
bigpaulo is offline   Reply With Quote
Old 01-29-2004, 12:28 AM   #7
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
durning the summer it would cycle on and off every 5 seconds.. which was shorter then when I first got the car.
HVAC problem sum0325 Electrical & Lighting 8 02-15-2009 06:33 PM
HVAC problems Matt Mid Atlantic Impreza Club -- MAIC 0 02-23-2008 09:44 PM
HVAC problems qoncept Service & Maintenance 2 12-19-2005 03:58 PM
HVAC Problem 98LegacyGT Legacy Forum 4 12-10-2003 04:19 PM
HVAC Problem 98LegacyGT Electrical & Lighting 2 12-10-2003 11:17 AM
