#1 |
Member#: 33489
Vehicle:1995 Imp 2.2L Coupe Sedona Red |
ello!
I have a 1995 Impreza 2.2L coupe, Sedona red. I bought the car used in 2002. Well, in July of 2003 I had a custom exhaust from a well-known muffler shop in Albuquerque, New Mexico (from where I am originally from) done on the car. It included a high flow cat from the manifold, a 2 and 1/4 wide pipe ending with a Dynomax muffler. No problems after it was installed, until... About the middle of December 2003: it threw a check engine light. I had a dealership (out in Omaha, Nebraska, where I'm out here for college) pull the code off, and it said a deficiency in the O2 sensor. They cleared the code from the computer. Last night it threw the same light, I got angry and just had Autozone pull the code off for free, and it was the SAME code. Any suggestions on where I should go from here? Should I honestly replace the O2 sensor with one that can hanlde the difference from the change and, if so, where I go from there? Thanks much!
#2 |
Member#: 46399
Vehicle:0000 Knows nothing, about nothing. |
O2 sensors just go bad, replace it...
either get one OEM online from like www.subaruparts.com, pick a bosch universal up and splice it yourself... doesn't really matter, recommended replacement is 60k on o2 sensors i just wait till they go out of spec |
| Thread Tools | |
| Display Modes | |
| 06 STI BOOST Problem - Any Suggestions? | QueensKid | Factory 2.5L Turbo Powertrain | 32 | 01-04-2007 01:27 PM |
| Ant problem, any suggestions? | xothermic | Off-Topic | 16 | 06-22-2005 11:18 AM |
| ECU problems, any suggestion?? | ezaldere | Electrical & Lighting | 0 | 07-08-2004 07:47 PM |
| ECU problems, any suggestion | ezaldere | Service & Maintenance | 8 | 06-30-2004 10:08 PM |
| Door light problem.. any suggestions? | Herojin | Electrical & Lighting | 3 | 05-23-2003 05:19 PM |
