Old 01-26-2004, 01:48 AM   #1
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Default New CR, Off Boost Fuel Adjustment (Link Plus)
Tomorrow I am supposed to start up my 2.5 RS, which has just undergone a USDM STi motor swap, along with a host of other power parts.
My car was previously tuned with RC 440cc injectors on a 10:1 compression ratio. I am curious to know just how far off, if at all, my A/F will be with the new compression ratio, which should be around 8.3:1. Obviously there is now more volume in the cylinder area, so maybe more fuel?
Will I have to undergo drastic changes in my A/F and timing maps, or the new CR not have that much of an effect off boost?
Thanks for any info. I'm just sort of curious where I should start with it.
Graham
Graham is offline   Reply With Quote
Old 01-27-2004, 12:56 AM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
man i wish i could be turning my car over
what exhaust manifold did u go w/?
alex
Old 01-29-2004, 04:21 PM   #3
Section 8
Member#: 821
THere will be no change off of boost with your fueling. Your pistons still sweep the same volume, and if you didn't change your heads at all, you will have the same amount of air entering as before, your compression is just lower. If the car is cold or hot, your startup might change a bit from before though.
Greg
Section 8 is offline   Reply With Quote
Can the Boost/Fuel cut be turned off with any maps for the 06 STI? smac AccessPort 18 10-12-2006 10:32 PM
Wrx/STI lateral adjustable links, Catback Exhaust off a 2006 STI, STI Rockblocker bra kccobra Private 'For Sale' Classifieds 9 02-13-2006 08:07 PM
Boost/fuel cut-off CEL, Stage1 STi shutterbug Texas Impreza Club Forum -- TXIC 25 12-12-2005 10:15 PM
CR Article- Real Fuel Economy Lower than EPA gumball News & Rumors 25 09-16-2005 01:33 PM
FS: NEW JIC FLT-A2, Defi BF Boost gauge, Defi-Link Meter, Legacy B4 Intercooler sleepy-scoobie Bay Area Impreza Club Forum -- BAIC 30 05-15-2003 11:20 AM
