Old 01-26-2004, 03:25 AM   #1
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Default ARP 2.5" wheel studs info
Part Number ARP-100-7708.
If you plan to run these you will need new lug nuts. 12x1.5, open end, and acorn style. I found these at Summitracing.com (their brand lug nuts).
If you plan on installing these in the rear you will have to remove the axle nut to gain the clearance needed to fit them. Once I figured that out, I decided it wasnt worth it.
BTW This is for a 01 RS, I don't know how it is on other vehicles.
-Chav
Chav is offline   Reply With Quote
Old 01-26-2004, 07:02 AM   #2
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
The type of wheel nut should be determined by the type of wheel you have don't you think?
Most of the aftermarket wheels use the tapered type, the only reason I can think to do this is if you don't have hub rings.
ellisnc is offline   Reply With Quote
Old 01-26-2004, 02:19 PM   #3
Chav
Member#: 3269
RSTi
I should have mentioned, the "acorn" type is for the stock subaru wheel.
-Chav
Girodisc 2 Piece Lightweight Rotors STi!!! Ferodo/Hawk Pads! ARP Wheel Studs and More Innovative Tuning Suspension/Brakes/Handling 14 04-29-2008 10:39 AM
Kartboy, STi, Spec, ACT, Exedy, Cusco, Kaaz, Quaife, ARP Ext. Wheel Studs Innovative Tuning Drivetrain 59 10-29-2007 05:28 PM
GB: ARP Extended Wheel Studs For Your Suby!!! Innovative Tuning Vendor 'Group Buy' Classifieds 1 03-22-2005 02:42 PM
ARP Wheel Studs BLACK02WAGON Tire & Wheel 0 09-26-2004 09:41 PM
arp wheel stud intall procedure mbwrx20 Tire & Wheel 1 10-21-2003 12:08 AM
