Old 01-26-2004, 06:07 AM   #1
2cati
Member#: 48669
2004 STi
Default Prodrive air->water intercooler
http://www.flat4engineering.com/main/index.htm
"This is also from the SEMA show. It is Prodrives new reversed hood scoop. Great it you plan on running a front mount or their new air to water inter cooler. I do not have a price yet and they won't be available until around spring so we are just guaging interest and trying to figure out how many we need to order."
Does anyone have any preliminary information as to what performance gains may be had on stock 2004 STi ?
I've already emailed Prodive directly - hopefully some was at the SEMA show and talked to the reps..
Thasks...
2cati is offline   Reply With Quote
Old 01-28-2004, 06:41 AM   #2
worry
Member#: 13461
Whereabouts on the site is this information?
worry is offline   Reply With Quote
Old 01-28-2004, 06:52 AM   #3
2cati
Member#: 48669
2004 STi
under Products -> Exterior -> GGA/GGB -> "PRODRIVE REVERSED HOOD SCOOP"
Old 01-28-2004, 11:58 AM   #4
TopKatz
Member#: 36793
04 WRX
Your question is not quite clear.
You will see no gains by installing a revers scoop on your car. This scoop is mainly for people that install a FMIC and dont nead the scoop to force air into the IC.
A FMIC by it self will not produce any gains. IN fact if IM not mistaken installing a FMIC with out increasing boost will actualy losse power due to loss of presure.
A FMIC is usualy only installed after a biger turbo, or with a bigger turbo.
hope that clears it up a little....
TopKatz is offline   Reply With Quote
Old 01-28-2004, 04:04 PM   #5
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Subaru and Pro-Drive both experiminted with air-to-water intercoolers for use in their rally cars but the complexity and extra weight were not worth the HP gains. However there are some drag only cars using them.
wrx plus is offline   Reply With Quote
Old 01-28-2004, 06:49 PM   #6
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
anyone have any more info on this prodrive air->water intercooler?
el~sharko is offline   Reply With Quote
Old 01-28-2004, 10:48 PM   #7
2cati
Member#: 48669
2004 STi
1) I'm considering a FMIC or Prodirve's air->water if it becomes avavailable hence my post to the team for info.
Thanks all for your updates/info!
2) I would only consider the reverse scoop or "bolck off" plate if the FMIC or Prodrive's offering was installed.
Here is Prodrive's response:
From: "Sales" <[email protected]> > Thank you for your inquiry unfortunately the Reverse hood scoop and air/water intercooler is still in the development stages. As soon as more information becomes available it will be listed on our site. Dan Antonielli
Old 01-28-2004, 10:48 PM   #8
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
need to make reverse scoop for GDA, looks better that the aqua one.
Now I know how the GC8 guys must always feel
mr2guru is offline   Reply With Quote
Old 01-28-2004, 11:37 PM   #9
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
that website listed above doesn't know what GGA/GDA/GDB stand for.
nhluhr is offline   Reply With Quote
Old 01-29-2004, 08:06 AM   #10
Bolster
Member#: 22290
2002 WRB WRX Wagon
Yeah, 2004+ sedans are still GDA/GDB and wagons are still GGA (and they've dropped the GGB) right?
Bolster is offline   Reply With Quote
Old 01-29-2004, 03:35 PM   #11
wrx plus
Member#: 42253
2003 RWD WRX
Air to water intercoolers can be had from many different vendors, spearco I believe will even mak'em any size you want, and far cheaper than pro-drive is likely charge.
Old 01-30-2004, 12:28 AM   #12
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
anyone come across any pics?
Old 01-30-2004, 05:59 AM   #13
2cati
Member#: 48669
2004 STi
Yes - unfortunately for me I do not have time to "tune" a set-up or educate myself on what size unit, water pump, radiator, brackets & associated mods only to loose horspower, reliability or driveabilty.
I'd rather pay "extra" and know there was development/tuning work with tangeable Dyno results.
Thanks for the info - it was interesting seeing the various air->water IC that Spearco had.
Old 01-30-2004, 02:40 PM   #14
georgiawrx
Member#: 51152
2003 WRX
For those interested in this check with Airbourne Motorspots in Atlanta..they are developing one right now for the WRX..Call 877-869-2267..I just found out about it,when i ordered my up-down puipe from them..
georgiawrx is offline   Reply With Quote
Old 01-30-2004, 03:21 PM   #15
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
These guys sell a kit too. Seem pretty reasonable. $1200
http://www.gfactorwrx.com/2partsindex.html
silver arrow is offline   Reply With Quote
STi air-water intercooler?? kotaro Legacy Forum 22 12-19-2002 01:51 PM
Air/Water intercooler install, any suggestions? BlueDemon South East Region Forum 3 08-25-2002 09:39 PM
jdm newage impreza wrx sti air splitter/intercooler spray Benjamin Tang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-26-2002 07:50 AM
Air/Water intercooler? FuZZyLoGiC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-29-2002 11:45 PM
Interesting Air/Water intercooler thought Legacy GTR Normally Aspirated with bolt-on Forced Induction Powertrain 9 02-13-2002 11:53 PM
