Old 01-26-2004, 09:26 AM   #1
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Default Teeny tiny oil leak?
Well it leaked coolant so I had to replace the water pump, it leaked fuel when cold so I had to tighten up the fuel line clamps, now every once and a great while after a cold start I notice a very very slight smell of leaked oil, doesn't happen very often and it's not much in frequency (i.e. i changed the oil 2500 miles ago and not a drop is missing), any ideas where to check?
if it is leaking it's not even enough to really notice, cam seals & crank seal were inspected during tbelt/water pump replacement.
overdose is offline   Reply With Quote
Old 01-26-2004, 10:27 AM   #2
4npower
Member#: 9018
02 WRBP WRX
Slvr 06.5 Jeep Grnd SRT8
Mines gone threw 2 sets of cam Seals and a Oil pump seal. Jack you car up lay under it and look on the driver side of the header and see if there and oil burns.
4npower is offline   Reply With Quote
Old 01-26-2004, 10:34 AM   #3
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
were you noticing oil loss?
Old 01-26-2004, 10:38 AM   #4
4npower
Member#: 9018
02 WRBP WRX
no just smell after running it hard and driving in the snow. Took it to Subaru at 10k and had one set of cam seals done, 18k another set , 20k they said oooo it wasnt that it was a oil pump seal. And now at 26k still smell it and dont care b\c i change my oil every 2500 and i check it twice a week and it never changes on the dip stick.
Old 01-26-2004, 03:17 PM   #5
MarkRx
Member#: 42242
2006 STI
are you using Mobil-1 ?
MarkRx is offline   Reply With Quote
Old 01-26-2004, 05:38 PM   #6
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
i'm using mobil1, no noticable oil loss/consumption, just this slight smell very occaisionally
Old 01-26-2004, 08:19 PM   #7
4npower
Member#: 9018
02 WRBP WRX
If i recall i was at the time of the leaks
Old 02-23-2004, 10:38 AM   #8
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
i get an oil smell also... comes from right around just left of the TB, if your looking at it from the front of the car. Right about where you would put the Oil pressure sender. It seems on one of the hoses that there is some oil residue.
03WRX83 is offline   Reply With Quote
Old 02-24-2004, 08:34 AM   #9
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
mine too, at it manages to blow up in the bottom of the IC, IC hoses, inlet tube...just about everything in the area. I took everything off one day and cleaned it up like it wwas new, put some high temp sealant goo on the hose and put it back on...it helped untill i moved the hose again
Wheeler Bement is offline   Reply With Quote
Old 02-24-2004, 02:10 PM   #10
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
i wonder if its a faulty hose or something..
Old 02-24-2004, 10:25 PM   #11
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
Faulty CAR. lol...mine dumped oil a tiny bit then BAM...a Qt every 500 miles. Turbo seal we fig'd....replace n rebuild...3k later...BAM same thing...I wonder if I have something stuck in the coolant lines that heats the turbo up too much?!?!
Ur guys sounds like u need a catch can. All turbo car's get oil in the intake And those "return" vaccum lines, one runs to the PCV...check if ur's is still good.
WRX34
WRX34 is offline   Reply With Quote
Old 02-25-2004, 10:10 AM   #12
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
mine is leaking from the big hose that goes directly into the engine, then comes up and has 2other hoses connected to it, right next to the top gallery plug for my oil pres. sender.
possible oil leak and radiator leak MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2006 07:23 PM
Madden '06 Roster update has some teeny tiny errors.... Hazdaz Off-Topic 5 11-13-2005 05:04 PM
weird oil leak/AC leak? NateDogg Service & Maintenance 2 05-03-2004 04:23 PM
New Omori Oil temp install and oil leak mhbrown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-22-2003 07:10 PM
oil leak from front of engine, oil pump? drftsub Legacy Forum 14 01-06-2003 07:44 PM
