Old 01-26-2004, 11:01 AM   #1
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
Default Need some help, Hypothetical Situation
I'm thinkin about pickin up an extra td04 turbo and having it sent out to Deadbolt for the Monster TD04 port and polish.
Ive read that with this the turbo is capable of 17 psi and holding it.
Now my question is..
Can you run the CobbAccess ECU 2 with the Monster td04 turbo, and control it with either a MBC OR EBC set to 17psi?
Which is better way of controlling the boost with the AccessECU , the mbc or ebc?
I currently am cobb stage 2, and wondering if it is possible to use the EBC to make 17psi.
03WRX83 is offline   Reply With Quote
Old 01-26-2004, 01:07 PM   #2
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
You map will be all wrong for an upgraded turbo. The vf34 map would be much better but still wrong. You would need a custom tune.
mbiker97 is offline   Reply With Quote
Old 01-26-2004, 01:17 PM   #3
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
To get the full potential out of the turbo you would need a custom tune. Running an MBC with a cobb stage 2 deffinately has its risks. ie: running more boost up top than the stage 2 is mapped for, causing detonation.
On another note, I don't think the deadbolt td04 will hold 17psi to redline... not sure where you heard that from.
I just picked one of these up used and will do a write-up/comparisson with a stock turbo shortly.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 01-26-2004, 02:43 PM   #4
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
but you can run 17 psi safely..? how do you like the turbo?
Old 01-26-2004, 07:41 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
The turbo is not in yet. You can run 17psi safely on a stock td04 but it won't hold it to redline.
-- Ed
I need some help about a roommate situation... lackofhp Texas Impreza Club Forum -- TXIC 52 08-28-2007 04:13 PM
Need some help with a tire situation j420n Tire & Wheel 19 12-05-2006 11:45 PM
Need some help with a unique birthday situation... Anub1s Off-Topic 41 10-19-2006 07:08 PM
Possible Impreza purchase, have some ?'s, need some help. STi2001 Normally Aspirated with bolt-on Forced Induction Powertrain 4 10-14-2001 11:10 PM
I need some help and some answers coloradobound Normally Aspirated Powertrain 3 02-23-2001 02:01 PM
